Re: airwolf sbm 220 heads!!!! for a sb mopar
[Re: fishy340]
#1300020
09/08/12 11:25 PM
09/08/12 11:25 PM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Very nice. I said it before and I will say it again. These are great days for those of us racing MOPARS. Here's a link to the above post. http://www.yellowbullet.com/forum/showthread.php?t=129971&page=98
[Re: skrews]
#1300023
09/11/12 09:50 PM
09/11/12 09:50 PM
Posts: 20,655 in a cattle trailer down by th...
Guitar Jones
Quick somebody run out and buy a set. Let us know if they're any good or not.
That's a great idea, why don't you do it? I have way too much invested in my W5's to even consider changing anything at this time.
[Re: fishy340]
#1300025
09/12/12 06:54 AM
09/12/12 06:54 AM
Posts: 793 Utah
topbrent
Utah
[Re: DemonDust]
#1300030
09/13/12 06:59 AM
09/13/12 06:59 AM
Posts: 429 Washington
skrews
Washington
If these come out at a good price I can see Rods stroker cranks flying out the door. They say things happen in 3s. So we have Rods cranks, these heads, and what do you think will be the topper for the SB world?
Now we need an AFORDABLE siamese 4.125 bore block with 4 bolt splayed steel caps.
[Re: RAMM]
#1300032
09/13/12 08:49 AM
09/13/12 08:49 AM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
It says in that post its an imported casting so that should hold the price down some.
[Re: pittsburghracer]
#1300033
09/13/12 10:57 AM
09/13/12 10:57 AM
Posts: 9,881 Weddington, N.C.
Streetwize
Weddington, N.C.
was 323 @ .700 now 316 @ .700 and now publishing @.900 lift RAMM, I agree and understand port stall but for the majority of people (running something like a CompXE 284 at ~.525 of flat tap lift) it's not much better "real world" than a set of ported Eddies. With flat tappets the flow at peak really means less (it's more comparable to a roller measured .050 or .100 less than the FT peak since there's no real 'effective duration" at the peak of a flattie). Like you, I'm sure I always compare/measure/calc the % gain from the previous lift point rather than just look at the peak numbers at face value. Overall I was more impressed with Brian @ IMM's 305 cfm Eddies that he ran the pushrod tubes through. I think they were even better through the middle (where it does the most good) than these. BTW....I'm also impressed with the work you guys up North of the border are doing too. Mid lifts (.200-.500) still look good but not Amazing, my point on the high lifts is anyone running a .700+ lift cam is going to want a bigger/better/offset rocker intake head to start with
[Re: Streetwize]
#1300034
09/13/12 12:14 PM
09/13/12 12:14 PM
Posts: 1,051 The Great White North
RAMM
Oh I totally agree that if you plan to run huge lifts or large cubic inches then yes a standard port window head/no-offset rocker is NOT worth it. That's why I would bet these are aimed at the 4" and larger stroke STREET crowd 'cuz I see no place for them on anything serious.
As for low lift flow numbers--I don't want great flow rates at anything under .400"--even street stuff. I have done some testing with high low lift flow (30* seats) and it sucked--even on a street engine.
For example I was degreeing the cam on my 416 yesterday and measured that the intake valve was open more than .225" with the piston going the WRONG way. You can imagine what happens when you have great low lift flow numbers in that scenario. With all that being said--thanks for the compliment, but I still think it will be a powerful head for 95% of the people who buy them and stick them on 400+ cube small blocks that won't see much over 6000rpm. I do think the chamber is ugly however-but looks aren't everything. J.Rob
p.s. I do think we're trying to say the same thing--It boils down to choosing the best parts for the application. Question is-What application suits these heads best?
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: RAMM]
#1300036
09/13/12 12:33 PM
09/13/12 12:33 PM
Triple Threat
Renton Washington
I think it will be a good in between head. Possibly an upgrade for someone who already has good rockers, intake and headers for the standard SBM layout but wants a little more giddy up. I have ported eddies currently that flow 280@.600, granted there should be some more on the table with these, but instead of sending them back for more porting, these new heads might be a better bargain. All depends on where the price point ends up. We all know what a CNC'd Indy top end costs. If they can price them significantly less than that I think they will sell well.
