Long wheel stud question? #1299914
09/08/12 08:59 PM
09/08/12 08:59 PM
illinois
bigblk66_coronet Offline OP
illinois
Hey guys i want to switch over to long wheelstuds on the rear of my car. Im running an 8 3/4 in my 66 coronet. Not sure how to go about finding the right ones. Which ones do you suggest?....Joe
Re: Long wheel stud question? [Re: bigblk66_coronet] #1299915
09/08/12 10:11 PM
09/08/12 10:11 PM
Queens, N. Y.
FASTBACK340 Offline
FASTBACK340  Offline
Queens, N. Y.
I just installed a set of Moroso 2 3/4" studs on my car. I pulled the axles and used the hydraulic press at work. The axles must come out, so you might as well re-pack the wheel bearings and swap out the axle seals. The means draining the rear so don't forget the sure grip additive and gear oil. I bought a nice hand pump at Auto Zone that screws onto the bottle and makes filling the rear a breeze. Also make sure you use anti-seize on the wheel studs & lug nuts. As for the actual selection of what to buy, most catalogs walk you through the choices.
`68 Barracuda 340-S
Re: Long wheel stud question? [Re: bigblk66_coronet] #1299916
09/08/12 10:17 PM
09/08/12 10:17 PM
WI, USA
67dodge67 Offline
mopar addict
67dodge67  Offline
mopar addict
WI, USA
Contact Dr. Diff on here. He is a member on Moparts and is extremely well known.
Re: Long wheel stud question? [Re: 67dodge67] #1299917
09/09/12 07:28 AM
09/09/12 07:28 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
No need to drain the rear as the center section dosent come out.Installed the Moroso studs in my 65 and the kids 62 with newer rear end.You can actually install them by just knocking the axle studs out first.Then loosen the axle nuts and pull them out a bit.Install the new studs and use an old nut reversed with washers under it.Pull the studs thru the axle end and you are done.No press needed.On mine I needed to pull the axles all the way out so I used a deep well socket under the axle flange and the stud went in it and I just smacked them into the axle.Been 10 years and no problems.Did the same with the fronts.Rocky
Chrysler Firepower
Re: Long wheel stud question? [Re: therocks] #1299918
09/09/12 08:03 AM
09/09/12 08:03 AM
Queens, N. Y.
FASTBACK340 Offline
FASTBACK340  Offline
Queens, N. Y.
Maybe I should have clarified my post:
The CORRECT way to install axle studs, especially when the opening on my A body axles is .680 and the replacement studs are .720, is with a press. No need to stress-test the studs and pull them through over-tightening the stud with a socket jammed over it. It lasted 10 yrs? Good for you.
And yes, if you pull both axles, it will leak out. Or you can wait until it's dripping and go look for a pan. Or just let it drip while you hammer in the studs....
`68 Barracuda 340-S
Re: Long wheel stud question? [Re: therocks] #1299919
09/09/12 08:44 AM
09/09/12 08:44 AM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
I did my '65 exactly the same way the Rocks did using the proper size studs (two different shoulder sizes are available). I seem to remember that mine were Mr. Gasket.
This is the land of the free because of the brave
Re: Long wheel stud question? [Re: rbstroker] #1299920
09/09/12 09:02 AM
09/09/12 09:02 AM
Queens, N. Y.
FASTBACK340 Offline
FASTBACK340  Offline
Queens, N. Y.
.040 difference is the closest you come with A body axles. Instead of trying to pull the studs through by over-tightening them I'm positive it's better to use a press. But I've only been wrenching for 35 yrs. and haven't seen much.
But at the end of the day again, different people, different methods. What ever works for you. I was just trying to help (what sounded like...) a novice asking for advice. I try not to give short-cut, pound-it-in advice. Us pro's can do that...
`68 Barracuda 340-S
Re: Long wheel stud question? [Re: bigblk66_coronet] #1299921
09/09/12 10:01 AM
09/09/12 10:01 AM
You need to verify the diameter of the shoulders on your studs in your axles, have one removed and measure the shoulder. Mr Gasket and Moroso use to sell them, probally still do I've done several stock axles over the years, it is not easy but can be done as already mentioned on here, several viable options are safe
Re: Long wheel stud question? [Re: bigblk66_coronet] #1299922
09/09/12 10:19 AM
09/09/12 10:19 AM
MS
redex79 Offline
redex79  Offline
MS
I did the same thing. Got the knurl size and matched it to Moroso 3" wheel stud part number 46190. Stock wheel stud for my 66 Belvedere with a 361 was .673, moroso size for there part was .685.
Truckin Weekend !
70 Dodge Dart Swinger
11 Ram 1500 Laramie 4x4
21 Dodge Durango GT
Re: Long wheel stud question? [Re: redex79] #1299923
09/09/12 01:29 PM
09/09/12 01:29 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
FWIW, unless your wheel center thickness requires it, a somewhat shorter stud (like 2") makes it easier to get the wheels on/off in tight confines. I prefer the dog-point style to the fully threaded, as the nuts are easier to start and much less prone to garfed threads.
Re: Long wheel stud question? [Re: topside] #1299924
09/09/12 01:47 PM
09/09/12 01:47 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yup I have like 3" on my car, 2" would be better.
When I put mine in I pulled the axles and took one out and measured it and got them from a auto parts store. At the time Dorman was selling them.
I would not use Moroso or MP because of the stories I have been hearing about galling.
Buy the best ones you can and not from the above venders, imo.
Re: Long wheel stud question? [Re: redex79] #1299925
09/09/12 01:48 PM
09/09/12 01:48 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
The only long wheel studs the fit correctly are made by Mr Gasket.
http://www.summitracing.com/parts/MRG-4311/
Re: Long wheel stud question? [Re: DoctorDiff] #1299926
09/09/12 01:52 PM
09/09/12 01:52 PM
Cincinnati, Ohio
Cincinnati, Ohio
Thanks for your post, do the Mr Gasket studs gall like some of them?
Re: Long wheel stud question? [Re: Challenger 1] #1299927
09/09/12 02:00 PM
09/09/12 02:00 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Moroso studs are notorious for galling. I haven't heard of a problem with Mr Gasket.
Anti-seize never hurts, however.
Re: Long wheel stud question? [Re: DoctorDiff] #1299928
09/09/12 02:01 PM
09/09/12 02:01 PM
Cincinnati, Ohio
Cincinnati, Ohio
Thank you
Re: Long wheel stud question? [Re: Challenger 1] #1299929
09/09/12 02:17 PM
09/09/12 02:17 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
ARP and Milodon studs are good quality, but their knurl diameter distorts the axle when installing.
Re: Long wheel stud question? [Re: Challenger 1] #1299930
09/09/12 03:08 PM
09/09/12 03:08 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Any reason why you suggest to not buy from the above mentioned vendors like doc diff? Or did you mean something else?
**Photobucket sucks**
Re: Long wheel stud question? [Re: bigblk66_coronet] #1299931
09/09/12 03:55 PM
09/09/12 03:55 PM
AndyF Online content
AndyF  Online Content
Dorman studs are the way to go if you just want a little extra length.
Be very careful when selecting aftermarket studs. Most of them do not fit on a Mopar regardless of what the mfg says. The axles usually need to be reamed out to work properly with aftermarket 3 inch wheel studs.
Re: Long wheel stud question? [Re: 70Cuda383] #1299932
09/09/12 04:59 PM
09/09/12 04:59 PM
Cincinnati, Ohio
Cincinnati, Ohio
I meant MP or Moroso because of my experience with MP and what Dr Diff has told us about Moroso.
Re: Long wheel stud question? [Re: Challenger 1] #1299933
09/09/12 06:54 PM
09/09/12 06:54 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Another thing: I bought a set of the Summit studs a while back, and had to chase the threads on several of them with a die to get the threads happy.
I always use a small dab of anti-sieze on lug threads.
