Page 1 of 3 1 2 3
UNDERCHASSIS HEADERS FOR A A-BODY #1299057
09/07/12 03:34 PM
09/07/12 03:34 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline OP
Do they make a under chassis header for a A-Body with a 440???? Or would you just build/buy a 400 B motor for more clearance??
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: MIKES_DUSTER] #1299058
09/07/12 03:53 PM
09/07/12 03:53 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
what are you up to mike changing from small block
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: MIKES_DUSTER] #1299059
09/07/12 04:15 PM
09/07/12 04:15 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
yes they do TTI which is what i have on my 73 dart and Maddog does also. i know there is one more but i can nto remember there name. also it will make a diffremce with the 440 if you will be useing the indy-1 or the Indy SR heads witht he raised exhaust ports. mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: MIKES_DUSTER] #1299060
09/07/12 04:30 PM
09/07/12 04:30 PM
Greenville, South Carolina
BBLM23 Offline
BBLM23  Offline
...would you just build/buy a 400 B motor for more clearance??
Walter
1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph
Racing Pro in street trim.
1981 Aries ARC 548 B1 8.88 at 147mph (footbraking)
1996 Ram 2500 V10 16.52 at 80mph
1981 Reliant 400
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: MIKES_DUSTER] #1299061
09/07/12 07:12 PM
09/07/12 07:12 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I like the Pro Parts headers.They work with either 383 or 440.You can run a larger tire,don't have to pull the T-bars to install them,starter is a breeze(on 440,383 is a bit snug dropping it out)nad although they are a semi fenderwell header,they fit very well.Bob Mazzolini sells them,and the new ones are made by TTi.
Nautilus Racing-
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: MIKES_DUSTER] #1299062
09/07/12 07:14 PM
09/07/12 07:14 PM
The 440 chassis headers like the older Pro Parts don't fit worth a hoot on a low deck with stock mounts I bought a set of the older Pro Parts from Bill before Mazolini bought the Name, inventory and rights to have new ones made, mine don't fit worth a hoot on my 1969 Dart GTS with the original 383 K member and mounts I bought a set of the 383 headers from a member and sent the left side back to Mad Dog to have him fix what the other guy bent up I was going to swap them but I have since bought a stock set of 383 exhaut manifolds for my car I'm going to keep one set of the headers for making dyno headers with EGT fittings but the other set may be availble, let me see and if so I'll post about that on here
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: Chris2581] #1299063
09/07/12 08:31 PM
09/07/12 08:31 PM
southern Maryland
K
keefe Offline
keefe  Offline
K
southern Maryland
TTi.
they are so much easier to work with ...Keefe
1971 duster twister 440, 3380#,509 M/P hyd,906's,full Exhaust,11.06@117.46 1/4,6.95@ 97.03 1/8,1.497 60ft.....
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: keefe] #1299064
09/07/12 09:11 PM
09/07/12 09:11 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
TTi.
I am leaning HARD toward the Pro Parts if I can find some. The TTI's are a PITA to do any engine/starter work. I have my engine/trans out right now, and thinking very hard about doing away with the TTI's...any body got any Pro Part headers to trade..??
If you like drag racing, support your local track.
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: CHAPPER] #1299065
09/07/12 10:00 PM
09/07/12 10:00 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
We have the pro parts on the Duster and its a little old 383 with -1 heads which made up the deck height to almost what the stock 440 would be. The only tube that I had problems with was the drivers side rear. They told me to trim the steering shaft where the collar comes down about 5 inches. Other than that, I love them. I was limited to a 24" tire and now I run 27" .. More roll out
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: 70dusterjohn] #1299066
09/07/12 10:02 PM
09/07/12 10:02 PM
Deerfield, Ohio
Deerfield, Ohio
Oh and it And has a stock big block k-member out of my Dart. Soooo I didnt have problems with them..
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: 70dusterjohn] #1299067
09/08/12 05:38 PM
09/08/12 05:38 PM
I aint doing nuttin cause I have no CASH!!!!!! LOL I was just curious because I always wanted to build/buy a 451/474 nitrous motor.
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: MIKES_DUSTER] #1299068
09/08/12 06:49 PM
09/08/12 06:49 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Like what I'm hearing.... "torsion bars, K member interferance"... all crap our 70 Duster no longer has! Carry on....
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: CHAPPER] #1299069
09/08/12 07:51 PM
09/08/12 07:51 PM
you have a PM
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: MIKES_DUSTER] #1299070
09/08/12 07:55 PM
09/08/12 07:55 PM
New York
Dustin71 Offline
Dustin71  Offline
New York
TTI Buddy... I just went that route and i'm very happy with the Fit...A-Body W/440 tti.....
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: Dustin71] #1299071
09/08/12 09:00 PM
09/08/12 09:00 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I don't SEE any headers in the pic????
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: CHAPPER] #1299072
09/08/12 10:21 PM
09/08/12 10:21 PM
mopar65 Offline
mopar65  Offline
here is a pic of the tti in my 73 dart. Mopar65
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: CHAPPER] #1299073
09/08/12 10:24 PM
09/08/12 10:24 PM
New York
Dustin71 Offline
Dustin71  Offline
New York
Thats cause there chassis Headers lol... Sorry...Here's Some Better pics..
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: mopar65] #1299074
09/08/12 10:24 PM
09/08/12 10:24 PM
mopar65 Offline
mopar65  Offline
other pic. Mopar65
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: Dustin71] #1299075
09/08/12 10:28 PM
09/08/12 10:28 PM
New York
Dustin71 Offline
Dustin71  Offline
New York
Another pic..
Re: UNDERCHASSIS HEADERS FOR A A-BODY [Re: Dustin71] #1299076
09/08/12 10:34 PM
09/08/12 10:34 PM
New York
Dustin71 Offline
Dustin71  Offline
New York
Another...
Page 1 of 3 1 2 3
