Re: Rev-n-nator ignition boxes.... Anyone tried them?
[Re: mikemee1331]
#1298829
09/09/12 12:48 PM
09/09/12 12:48 PM
Posts: 6,100 Valencia, España
NachoRT74
Valencia, España
I think the problems are with newer units, not olders
[Re: NachoRT74]
#1298830
09/09/12 01:14 PM
09/09/12 01:14 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
you are in a better position than most people here to answer that since you tried rebuilding them! did you see any difference?
[Re: DaytonaTurbo]
#1298832
09/09/12 09:33 PM
09/09/12 09:33 PM
Posts: 1,238 Nevada
dezduster
Nevada
Appriciation is hard to come by here on this little site known as moparts. SO, Dunnuck Racing THANK YOU for your efforts in testing,proving and being vigilant in the acuracy of your information of the REV-N-ATOR. Much recources spent surely. Dave Dudek you didnt have to post your findings, you could have choose to keep that as your little extra.It validated through a second independant and respectd source. Thank You To the R/T Garage- Troy and Laura Martinson THANK YOU FOR ENDURING THE CONSTANT questioning and critisism. Congrats to a fine product proven. To further prove your product and increase your sales get one to Eberger at Mopar Action let him test it. People dont always like what he says or agree with him but his technical advice is respected. ![](/ubbthreads/images/graemlins/thumbs.gif) oh and enjoy the ![](/ubbthreads/images/graemlins/drive.gif)
[Re: mikemee1331]
#1298833
09/09/12 10:39 PM
09/09/12 10:39 PM
NachoRT74
Valencia, España
need to find good quality transistors... the ones I found are chinesse junk, and only worked to discard where it weas the fail, what it prooved the fail was there.
Actually after get the Rev-N-Nator, left on a side the testing of more transistors, but will try to work on that again
[Re: dezduster]
#1298834
09/10/12 12:23 AM
09/10/12 12:23 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
.... get one to Eberger at Mopar Muscle let him test it. People dont always like what he says or agree with him but his technical advice is respected.
Whoa... DOUBLE insult! He writes for Mopar ACTION
[Re: Kern Dog]
#1298843
09/20/12 10:42 AM
09/20/12 10:42 AM
Posts: 7,982 Scranton, PA
Montclaire
Scranton, PA
I was told that in some cases, the box may not play well with the vacuum advance system. He said that since the Rev box uses digital circuitry, it responds a little differently when the timing changes with vacuum advance. He suggested either a trial and error with different adjustments within the vacuum cannister OR just plugging it off.
Well, I don't like that. Is this where the difference in HP gains is coming from, combinations of vac advance? I am guessing any dyno'd runs are probably plugged, as well as any race cars. I am leaning back towards a stock box after hearing this, but the HP gains are hard to pass up...
[Re: Montclaire]
#1298844
09/20/12 11:06 AM
09/20/12 11:06 AM
Posts: 3,704 MICHIGAN
DynoDave
MICHIGAN
Since dyno runs would be at WOT, and 0 inches of vacuum, I would not think the vacuum advance would have any impact on peak HP/TQ numbers. It could effect economy or part throttle/cruise performance. Was there any definition of what they meant by "doesn't play well"? Is it taking timing back out when it sees the vacuum advance try to run it up for economy? Does this lead to surging at cruise/part throttle driving? ![](/ubbthreads/images/graemlins/confused.gif)
Rev-n-nator ignition boxes.... NOW installed ,REPORT:
[Re: DynoDave]
#1298845
09/20/12 03:15 PM
09/20/12 03:15 PM
Kern Dog
Granite Bay CA
The man said that the reluctor gap moves around during mechanical and vacuum advance. The Rev box responds to the changes. Having the gap change in 2 instances can confuse the ECM and cause timing to bounce around. I told him that I have a MP distrubutor as part of an electronic conversion package and that my vacuum can was adjustable. He offers a 1 year warranty, which is simply unheard of with electronic parts. I think that it is worth a try. Over the last 3 years, I wiped 2 orange boxes and went with a used ECM from a pile I had. Call me naive, but I didnt know that there was that much of a difference in spark boxes. My understanding was that the Chrome and Orange ECMs were supposed to be of benefit only in the sky high RPMs, which I don't see. I run the mill up to 5800-5900. The testing of this unit showed that it provides gains everywhere in the RPM range. I was specially impressed with the consistancy as compared to the cheapest ECM which faltered in the 3000-4000 range. THAT is the range that should be noticeable. I dont drag race the car, but I might. It is a street car with a greater emphasis on cornering and handling. Mid range performance is my greatest interest.
[Re: Kern Dog]
#1298846
09/20/12 03:47 PM
09/20/12 03:47 PM
NachoRT74
Valencia, España
Is true that the gap moves around with the vacuum. That happens because the diff ratius built into the distributor.
The reluctor is perfectly centered, so the circle gets the ratio from center.
The pickup coil is on a baseplate with different center than reluctor, so the ratio draws diff
is simply and basic geometry
If you adjust incorrectly the gap, you can even BITE the reluctor when vacuum is working, depending on how much advance you apply.
THE ONLY SOLUTION IS... play with the pickup coil position, bending the bracket here and there untill get the SMALLER VARIATION AS POSIBLE.
I made it, and got .009 with vacuum off and 0.007 with vacuum activated. That was way before I adjusted the vacuum action with the 3/32" Hex key, what it was really big.
Now I shortened the vacuum action travel, I guess I must be in .009" off and .008 on, or MAYBE still the same .009
[Re: Kern Dog]
#1298848
09/22/12 05:40 PM
09/22/12 05:40 PM
mikemee1331
bethlehem pa
I just ordered one tonight. Earlier today I spoke with the owner on the phone. He was really friendly and is excited about the product. I like this. Even though the unit costs a bit more than I expected, I feel good that it is going to a business that has passion for what they do. I was told that in some cases, the box may not play well with the vacuum advance system. He said that since the Rev box uses digital circuitry, it responds a little differently when the timing changes with vacuum advance. He suggested either a trial and error with different adjustments within the vacuum cannister OR just plugging it off. From what I recall of the printed words of Rick Ehrenberg, I'm leaning toward keeping the vac advance functional as best that I can to maintain the best street performance. I'll report back once I get the Rev box and have a chance to compare.
please do report back. alot of guys are very interested but have little feedback aside from 'works great'.
