PARTS CALL INDY ROCKERS #1298759
09/06/12 10:28 PM
09/06/12 10:28 PM
SD800 Offline OP
SD800  Offline OP
Guys,I need a pair of Indy rocker to finish out the year, I need both rocker for the number eight cylinder, they are the blue 1.6 rockers.I do not want to but a new set because I have a set of 572-13 with Kessel rockers that I will be running next year.I need them by the first of the week so I can make it to Indy for the bracket finals.call me at 231 383 1755 or PM me
You'll have plenty of time to sleep when your dead, let's go
Re: PARTS CALL INDY ROCKERS [Re: SD800] #1298760
09/06/12 11:42 PM
09/06/12 11:42 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I should have plenty of spares...are these for _1's or ????????????
RIP Monte Smith
Re: PARTS CALL INDY ROCKERS [Re: CompWedgeEngines] #1298761
09/07/12 08:08 AM
09/07/12 08:08 AM
SD800 Offline OP
SD800  Offline OP
These are for the-1 heads, you have a PM.
