727 cast crank converter 10"440 or 340 #1298752
09/06/12 10:25 PM
09/06/12 10:25 PM
Louisville Kentucky
jimba12 Offline OP
jimba12  Offline OP
Louisville Kentucky
I need help will a converter that was made for a 440 cast. crank work on my friend 73 340 motor with a cast crank.
Re: 727 cast crank converter 10"440 or 340 [Re: jimba12] #1298753
09/06/12 11:13 PM
09/06/12 11:13 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
NO
I am truckless..
Re: 727 cast crank converter 10"440 or 340 [Re: 340SHORTY] #1298754
09/06/12 11:39 PM
09/06/12 11:39 PM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
NO
Are you sure? 6 bolt flange flywheels and flexplates interchange between the 340 and 440, why not a converter. Both can use the 10" flexplate. Tonight drilled out the holes on a small block 10" flexplate larger to use a Hemi converter on a 440 w/727 trans combination.
Re: 727 cast crank converter 10"440 or 340 [Re: Bull1tt] #1298755
09/07/12 02:50 AM
09/07/12 02:50 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
The balance is different between the 2 balancers. The balancers and torque converters are balanced for their apps. The flexplates are neutral..
I am truckless..
Re: 727 cast crank converter 10"440 or 340 [Re: 340SHORTY] #1298756
09/07/12 07:11 AM
09/07/12 07:11 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
MP used to sell the convertor weight package with instuctions for all the cast crank motors and the 440-6. You'd have to grind the old weights off your convertor and spot weld the new ones on. Dave
Re: 727 cast crank converter 10"440 or 340 [Re: quickd100] #1298757
09/07/12 10:24 AM
09/07/12 10:24 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
what they said , 340 cast has it's own specific balance weight.
Re: 727 cast crank converter 10"440 or 340 [Re: jimba12] #1298758
09/07/12 10:10 PM
09/07/12 10:10 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
You could knock the weights off the converter and then use the appropriate flexplate from B&M. http://www.summitracing.com/parts/BMM-10235/
