Drip Rail?? #1298293
09/06/12 01:06 PM
09/06/12 01:06 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Does anyone recognize what car this drip rail may be for??
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: Drip Rail?? [Re: 19cuda73] #1298294
09/06/12 01:07 PM
09/06/12 01:07 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
side view
1972 Corvette
Re: Drip Rail?? [Re: 19cuda73] #1298295
09/06/12 01:12 PM
09/06/12 01:12 PM
Western Colorado High Desert
moparmarks Online penguin-006
moparmarks  Online Penguin-006
Not 70/4 Cuda or 71/4B
Maybe Challenger, A-body or 66/70 B-body excpet Charger.
Would need some measurements
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Drip Rail?? [Re: 19cuda73] #1298296
09/06/12 01:21 PM
09/06/12 01:21 PM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
Those look like the rails on my '73 Duster. Can you take some over all measurements (end to end and over all height should work). I can compare them to measurements from mine for you.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: Drip Rail?? [Re: bigsbigelow] #1298297
09/06/12 02:34 PM
09/06/12 02:34 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Thanks guys I'll get those measurements tonight. And we can check it out.
1972 Corvette
Re: Drip Rail?? [Re: 19cuda73] #1298298
09/06/12 09:24 PM
09/06/12 09:24 PM
bigsbigelow Offline
bigsbigelow  Offline
The rails on my Duster measure 5 feet end to end and 15 inches from the top of the door to the rail (stand the rail so that long straight in the middle is parallel to the floor and measure form the floor to the straight to simulate a door to rail measurement).
Re: Drip Rail?? [Re: bigsbigelow] #1298299
09/06/12 10:08 PM
09/06/12 10:08 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
These measure 58.75 from end to end and are 15 high. Pretty close sounds like these might be for a duster. Thanks for your help
1972 Corvette
