68 Coronet R/T hood inserts ? #1297955
09/05/12 02:14 PM
09/05/12 02:14 PM
Mcgregor, Ia
493RT Offline OP
493RT  Offline OP
Mcgregor, Ia
What type of fastener was used to hold the inserts to the hood . Also is there a gasket between the hood and insert .
Re: 68 Coronet R/T hood inserts ? [Re: 493RT] #1297956
09/05/12 07:35 PM
09/05/12 07:35 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Here is the gasket. I'll take a picture of the fastener later tonight.
https://www.yearone.com/Product/DisplayProduct/357994
Re: 68 Coronet R/T hood inserts ? [Re: 68KillerBee] #1297957
09/06/12 07:29 AM
09/06/12 07:29 AM
PA
BTTG Offline
BTTG  Offline
PA
Fastener is a PAL nut. think these are them.
http://www.rtspecialties.net/proddetail.asp?prod=1003404
If not R/T spec does have the right ones just need to measure for right PAL nut size...
Re: 68 Coronet R/T hood inserts ? [Re: BTTG] #1297958
09/06/12 09:26 AM
09/06/12 09:26 AM
Mcgregor, Ia
493RT Offline OP
493RT  Offline OP
Mcgregor, Ia
Thanks guys...
Re: 68 Coronet R/T hood inserts ? [Re: 493RT] #1297959
09/06/12 09:36 AM
09/06/12 09:36 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
Just go to your local paint and body shop supply store and you can get the palnuts.
MLR426
