Re: What hp can a mega block hold
[Re: Mopar-Al]
#1297851
09/05/12 09:50 AM
09/05/12 09:50 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
You won,t hurt it with 440-1 or B1 heads. Go big on cubes to keep the revs down. A 4.375 or 4.5 stroke will yield enough cubes. That is 557 or 572 cubes. Go to as much compression as you want to run for the fuel you are willing to pay for. I run 15 to 1 and Methanol. My heads are cut down to 64cc to stay away from piston domes that are big. I only need about .080 dome to get the compression I have, and you may be able to run a flat top piston if you go 572 and still get very high compression. You will want to run a big roller if you want to make some real power. A great cam that is little known is an Isky rr735. The specs are 280/290/110 and I run it straight up. Lift is .761 with a 1.55 rocker, and that is what I ran the 8.77 with. Combine that with a 1.6 or 1.65 rocker, some very good rocker arms and springs, etc and a Dominator or Termintor injection on a 3x manifold and you are looking at 840 horse or more. I am running 8.90s at 3015 lbs in the heat at a DA of 2500 to 4,000 feet with only 528 cubes. Headers for mine are 2 1/8 by 30 by 4 inch collector that should be 12 inch long, but I can only get about 6 inches due to placement. A better combo for more cubes would be a two step of 2 1/8 to 2 1/4 or just 2 1/4 tubes with somewhere around 32 in primarys. A vacuum pump is worth 30 hp according to dyno study's. Run a 2.2 rod journal with GRP aluminum rods. This will be much easier on the motor because it is so much lighter than a steel rod 2.375 deal. I have been told by Crower that going to an even smaller rod of 2.1 (SBC size) will work and not be too small for my application. My pistons have .043 top and second rings, 4.50 bore. Low tension oil rings with a vacuum pump, standard without. Gap the rings at .022 top, .025 second. If you need to keep the cost down, you can use a flat tappet cam with the biggest motor . The .650 lift Comp cam with 290 duration at .050 will work well and my guess is you can get 750 to 775 hp out of the package with fully ported heads.
[Re: Mopar-Al]
#1297854
09/05/12 10:05 PM
09/05/12 10:05 PM
Posts: 6,295 U.S.
moparniac
U.S.
an ole buddy of mine no longer with us had an older 2 bolt mega block with -1 heads and it showed signs of cap walk.
Mopar Performance
[Re: gregsdart]
#1297863
09/06/12 04:43 PM
09/06/12 04:43 PM
Posts: 6,295 U.S.
moparniac
U.S.
alan no girdle. all ARP hardware.
Mopar Performance
[Re: moparniac]
#1297864
11/25/12 10:40 AM
11/25/12 10:40 AM
Posts: 4,424 Montgomery, AL
v8440
Montgomery, AL
I just bought this block from Al. I think it was cast in 2007, and was probably cast by cummins. Can you guys tell me how to determine for sure who cast it, and any bugaboos to look out for? I'm still trying to decide what bore/stroke combo it'll end up with, and I have plenty of time as it'll be a good while before I have the money for a rotating assembly.
Exactly 610 posts on old board, first whacked post in the history of this one!
Funny moparts quote from Waginator:
"*If you want your package lost, like bermuda triangle lost, use DHL (formerly airborne)
*if you want it to get there but destroyed, use UPS."
