Milling the front drum piston #1297563
09/04/12 09:42 PM
09/04/12 09:42 PM
Stow,Ohio
RBSat66 Offline OP
RBSat66  Offline OP
Stow,Ohio
I was going to mill .170 off the piston on the front drum to add an extra clutch, but after doing some measuring I have noticed that it would eliminate the two small outer ears on the piston. Is this going to cause a problem? First time rebuilding and upgrading a BB 727. It has a 4 disc drum and I want to put in 5. It is 1977 Tranny.
Re: Milling the front drum piston [Re: RBSat66] #1297564
09/04/12 10:53 PM
09/04/12 10:53 PM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
Instead of machining the weaker aluminum piston, step machine the thick outer pressure plate as shown in the picture.
Re: Milling the front drum piston [Re: DusterW2] #1297565
09/04/12 11:17 PM
09/04/12 11:17 PM
Stow,Ohio
RBSat66 Offline OP
RBSat66  Offline OP
Stow,Ohio
That won't weaken the pressure plate to much?
Re: Milling the front drum piston [Re: RBSat66] #1297566
09/04/12 11:56 PM
09/04/12 11:56 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
.170 is a lot , why are you taking so much off ? What clutch thickness are you using , what thickness snap ring .
Also you can step mill the pressure plate but that is taking more than half of it off (if I remember right)
Re: Milling the front drum piston [Re: RBSat66] #1297567
09/05/12 07:33 AM
09/05/12 07:33 AM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
Here is a pic of the machined pressure plate. You can also do the following:
** Machine some off the aluminum piston and some off the plate, use a 0.060" snap ring. Double check all your clearances before machining.
** Use a forward clutch inner pressure plate turned upside down. May have to clearance (remove) some of the raised section.
** Use thinner clutch frictions from A&A or CRT. You may be able to install 5 without machining anything.
www.aandatrans.com
www.coperacingtrans.com
http://www.aandatrans.com/Products/727-Direct-Friction-Red-Racing-Checkered-Thin__22595B-5.aspx
John
