I was using some info I found on this wiki page:
http://en.wikipedia.org/wiki/Adiabatic_processI'm an electrical engineer, not a mechanical engineer or physicist, so my knowledge of thermodynamics is limited.
I was just trying to get an idea of how changes in air and engine temp affect the compressed air/fuel temps prior to ignition, or pre-ignition if the temps are too high? I know the diesel engines rely on the heated air under compression to ignite the diesel when it is injected.
When I worked the Thermal equation using a 1.2 factor for y (or K?) I converted 100 degrees F = 310.93 Kelvin, with the V1/V2 (estimated dynamic compression) of 8:1, I got T2 = 471.28 Kelvin which converts back to 388.63 degrees F?
With a y factor of 1.3, T2 = 584.71 F,
and with a y factor of 1.4, T2 = 826.11 F.
I would the fuel and losses to the chamber would reduce the factor below the ideal 1.4 factor?
My guess is the 1.2 factor may be a closer estimate.
I think if I took the time, I might be able to model a "real gas" model, and chamber, piston, etc to get a more accurate model, but I thought one of the mechanical engineer, or automotive books may have an estimate or formula already worked out?
One of the technical books I have is "Internal Combustion Engines" by V. Ganesan. It is very technical, but does not always have values defined for variables.
Dang, when I grabbed the book to get the authors name, I flipped through it and found an estimate used in one of the examples (page 152, example 4.3.) In the example it says to assume the "index of compression" = 1.3?
