Re: Reserection of my old W8 Bullet
[Re: mafo]
#1296777
10/31/12 11:55 AM
10/31/12 11:55 AM
Posts: 636 Central,Ohio
FASTFISH420
Central,Ohio
Great job guys I think its making more than you think at that mph.that car must be working great and 60 in the low 20's..wow thats great..with the converter stalling low 5300 with a 4.57 gear?it must have a dinky camshaft in it.
1969 Barracuda 8 second all/motor small block
2014 Shelby GT500 Mustang
Uratchko Racing Engines
www.URE-RACING.com
[Re: FASTFISH420]
#1296778
10/31/12 12:23 PM
10/31/12 12:23 PM
Posts: 3,456 Out West
408strokerdart
Out West
Great job guys
Chris, your thinking on the cam is on the right track. Converter actually goes 5800 though.
[Re: W5DART66]
#1296779
10/31/12 05:38 PM
10/31/12 05:38 PM
Posts: 1,745 Maryland
340_Dart
Maryland
Your car will definitely fly Jeff. It'll be interesting to see the difference of 30 cubes and that big 420 intake Brett did for you. Brian's car is damn impressive for 416 ci.
I did not do intake for Jeff's car it will be Vic Bloomer doing that and he is doing chamber and exhaust port finishing.
I did have my large CNC intake port put in the heads and Dennis at AFD did the valve job.(I think we did valve job when heads were hear) correct me if I am wrong on that Jeff
Thanks again Brett Miller. OH CAN'T WAIT FOR THIS TO RUN JEFF!!!!!!!!!
My fault Brett, i thought the "big boy 420" intake you did was for Jeff's motor.
I'm gonna take a guess that the cam is in the mid 260's @ .050
[Re: W5DART66]
#1296781
10/31/12 10:39 PM
10/31/12 10:39 PM
Posts: 601 Niles, Michigan
Hitman340
Niles, Michigan
You are correct Brett.And yes you did the Valve job while you had the heads.Vic Bloomer is doing the rest of the build for me in trade for some chassis work We did on his car a cpl of years ago.This will be the first engine I have not done of my own but Vic is way sharper than I in that area.Bretts phone will be ringing more than just a few times befor this project is done. We are hoping when this thing is done I will have a good reason to buy sone 10.5 tires.
[Re: 340_Dart]
#1296782
11/01/12 10:15 AM
11/01/12 10:15 AM
408strokerdart
Out West
That's a good guess.
I still have this Chapman ported 598 intake that was butchered to accept a dominator. I might have to "fix" this for next year.
[Re: 408strokerdart]
#1296783
11/01/12 11:28 AM
11/01/12 11:28 AM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
Brian What would that equate to in the 1/4, 8.50 ish? Mighty impressive.
[Re: B3422W5]
#1296784
11/01/12 01:08 PM
11/01/12 01:08 PM
408strokerdart
Out West
Mighty impressive.
I'm guessing about an 8.70 ?
[Re: Otherlane]
#1296786
11/01/12 05:18 PM
11/01/12 05:18 PM
Posts: 1,019 Finland
mafo
Finland
I went 8.69 with a 5.57 and a 1.29 60 ft, and that is after years of trying, you make it look easy
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
#1296787
11/01/12 05:24 PM
11/01/12 05:24 PM
Triple Threat
Renton Washington
Standard formula is: 1/8th mile ET x 1.57 = 1/4 mile ET 5.5*1.57 = 8.635 Maybe a little closer to Brian's guess depending on how the car runs in high gear, it really 60's well
[Re: fishy340]
#1296789
11/01/12 10:30 PM
11/01/12 10:30 PM
408strokerdart
Out West
Put a 1250 dominator let the puppy eat.a little more desert!
Funny thing is that Brett has already suggested that. I would like to make a change to the intake and carb over the winter.
#1296790
11/02/12 08:58 AM
11/02/12 08:58 AM
Posts: 830 east coast
Otherlane
east coast
What size carb do you have now? If pro systems build a carb it mostly likely would be a 1100
[Re: Otherlane]
#1296791
11/02/12 09:24 AM
11/02/12 09:24 AM
408strokerdart
Out West
1050 Quickfuel Dominator, same one my dad ran on his 540 8 years ago.
#1296792
11/02/12 09:47 AM
11/02/12 09:47 AM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
I know this has nothing to do with accelerating a car, but we dynoed a 1.590 x 1.750 4150 on a 420 with a 2in spacer. Then we sent the 420 to Gabby who opened it up to dominator flange and we tried a 110mm blade SV-1 w/spacer.
We saw a 33hp increase. Obviously this huge increase was over a large 4150 and not a purpose built dominator.
