jetting carb with exhaust #1296463
09/03/12 08:32 PM
09/03/12 08:32 PM
Detroit
TX91971 Offline OP
TX91971  Offline OP
Detroit
I just added 3 inch full exhaust with 50 series flowmaster mufflers to my 440 950 hp has 78 all the way around and power valves, should I jet it fatter or leaner when you add exhaust? Thanks
Re: jetting carb with exhaust [Re: TX91971] #1296464
09/03/12 09:14 PM
09/03/12 09:14 PM
Central NC
gch Offline
gch  Offline
Central NC
Typically you would richen when a restriction has been removed.
However if you don't know whether you were rich,lean,or dead on before I would find out where you are now first before making changes.
Unless you were running 2" pipe or single exhaust before you may not have to change it at all.
Re: jetting carb with exhaust [Re: gch] #1296465
09/03/12 09:22 PM
09/03/12 09:22 PM
Detroit
TX91971 Offline OP
TX91971  Offline OP
Detroit
The car was running good had 2 inch tti's open headers I was just wondering what other people ran into that had there car running good and then put exhaust on. Did they richen the carb or lean it down. Thanks
Re: jetting carb with exhaust [Re: TX91971] #1296466
09/03/12 11:57 PM
09/03/12 11:57 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I didn't jet either way on my Duster when I went from open headers to a 3.5" exhaust, X-pipe, Dynomax bullets & turn-downs; plugs looked the same, no appreciable change in time slips. 368" SB, 904, 5.38, 13x31s, 3000lbs, low-10s footbrake car, exhaust was added when I was running it @ sea level. Not the same combo as yours, but that was my experience.
Best way to tell on yours is to do a plug-check run.
