Edelbrock big block heads
#1295732
09/02/12 03:46 PM
09/02/12 03:46 PM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
I've looked at different posts, but haven't found a definitive answer. Because of the angle plugs, is there a problem using stock '68-'69 exhaust manifolds on Edelbrock 60929 big block heads?
This is the land of the free
because of the brave
Re: Edelbrock big block heads
[Re: Dunnuck Racing]
#1295734
09/02/12 05:35 PM
09/02/12 05:35 PM
Posts: 4,321 Prospect, PA
BSB67
Prospect, PA
You can look at Andy 's website for some good articles covering this You could go to MP452 aluminum heads instead to get the same basic head with straight plugs Keith
If you have not purchased the Eddys, buy the Mopar 452s
[Re: rbstroker]
#1295735
09/03/12 09:43 AM
09/03/12 09:43 AM
rbstroker
West Tennessee
How do I access Andy's website? I haven't purchased yet, that's why I need the info. I really like the idea of the Eddy heads, but I don't want to run headers.
[Re: AndyF]
#1295741
09/03/12 05:52 PM
09/03/12 05:52 PM
rbstroker
West Tennessee
Outstanding. American made Eddy's it is.
[Re: rbstroker]
#1295742
09/04/12 07:07 PM
09/04/12 07:07 PM
rbstroker
West Tennessee
Last question; Is there a preferred (less expensive) supplier for the Eddy heads?
[Re: rbstroker]
#1295743
09/04/12 07:43 PM
09/04/12 07:43 PM
Posts: 31,078 Oregon
AndyF
The 452 head is a better choice for exhaust manifolds. I eventually switched heads on my engine just to eliminate the issue with the spark plug boots. When the Edelbrock heads came out I used them. When the 452 heads came out I switched. I have dyno tests and magazine articles covering both heads on my website. www.arengineering.com then click on tech articles.
[Re: rbstroker]
#1295744
09/05/12 11:00 AM
09/05/12 11:00 AM
BradH
Just a "heads up" (pun intended) that the MP '452' heads people are suggesting you use are more expensive than the standard Edelbrock heads.
[Re: BradH]
#1295745
09/05/12 11:07 AM
09/05/12 11:07 AM
Posts: 75,095 A Banana Republic near you.
JohnRR
I'll ask his question then ...
Is there a preferred (less expensive) supplier for the 452 heads?
