System 1 vs racor remote #1295605
09/02/12 10:30 AM
09/02/12 10:30 AM
mi
rbj Offline OP
rbj  Offline OP
mi
Ok trying to decide , witch is a better filter for a new build . 572 ,milodon dual line swing pickup, master lube 3 quart prelube/accumulator . my pump has normal screw on filter location should I just run a system 1 filter with sandwich plate for accumulator? Or my remote pacor lfs 60. Anyone run either or have any input.
Re: System 1 vs racor remote [Re: rbj] #1295606
09/02/12 11:48 AM
09/02/12 11:48 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
On my Master Lube I drilled and tapped into the top of the aluminum plate of oil pump.You can take the top plate off and see where you need to drill and tap. I will see if I can find a picture,if so I will post it.
PS I run the system 1 filter on mine,best $$$ I ever spent on a race engine.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: System 1 vs racor remote [Re: MRMOPAR622] #1295607
09/03/12 11:13 PM
09/03/12 11:13 PM
mi
rbj Offline OP
rbj  Offline OP
mi
thanks for the post ,i would like to see the pic of plumping.
