Re: Engine Stand Safety question
[Re: cudabitten]
#1295553
09/02/12 11:43 AM
09/02/12 11:43 AM
RapidRobert
A 3 wheeler will work IF it is heavy duty enough & the one in the pic looks to be a lightweight. When you move it pull it from the front & best is to also have a helper on the rear pushing. Myself I'd get a better one
[Re: RapidRobert]
#1295554
09/02/12 02:24 PM
09/02/12 02:24 PM
Posts: 10,766 North Dakota
6PakBee
North Dakota
I've had a three wheel version for years. It is somewhat unstable to any force applied perpendicular to the engine. Anything I torque I stand behind the stand and pull towards the head of the stand. Early on I made the mistake of pulling to the side and even with me holding it from turning, the stand almost went over. I've been looking for a good used four wheel version and once I find it, the three wheeler is history.
[Re: cudabitten]
#1295557
09/02/12 07:03 PM
09/02/12 07:03 PM
Challenger 1
Cincinnati, Ohio
My advise is to weld another set wheels on that thing and don't use it with 3 wheels. One of the dumbest things ever sold to us. Don't use it like it is, it's unsafe and stupid. Do they still sell 3 wheel ATVs?
[Re: None2Slow]
#1295559
09/02/12 07:44 PM
09/02/12 07:44 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Hot Rod Mag tested them and they are plenty strong took like 2000 lbs to bend one. Now like everyone says if actually working on the engine on it be careful they are easy to tip.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#1295560
09/02/12 07:55 PM
09/02/12 07:55 PM
Posts: 5,366 Rancho Cordova, California (Sa...
hemi71x
I once tipped over my hemi engine, moving it around on one of those 3 wheelers. Fell right onto the oil filter, cushioning the fall, somewhat, and putting a dent in the valve cover that i hammered out. Made a big mess, before i could engine hoist it back up again. 3 wheelers work, but you gotta be carefull with them. After that i bought an expensive 4 wheeler from NAPA, and never had to put it to use. Go figure.
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: hemi71x]
#1295561
09/02/12 08:21 PM
09/02/12 08:21 PM
Posts: 958 eastern, pa.
cudabitten
eastern, pa.
Thanks, its the same decision process for me everytime I purchase something for this project. Well, if I spend another 20 or 50 bucks, I can have the better this or that. So I have to cut costs somewhere, and only spend the extra when its most needed. So where do I skimp? On the thing that could kill me. I already started using this stand, I will not push it on the coasters. When I begin to torque things down I will make the decision to weld or bolt a front cross member. Probably will endup costing more than if I had just bought the better stand. Oh well. Thanks for your advice on this guys.
One last question, would I be able to start the engine on this?
[Re: cudabitten]
#1295562
09/02/12 08:30 PM
09/02/12 08:30 PM
Posts: 2,179 Walton, Indiana
TimS
Walton, Indiana
I just picked this stand up hoping to be able to take this 360 apart to the short block and re-assemble. I will not be turning the engine, just cleaning and re-assembling the pan, heads, intake, etc. Has anyone used this style, and will I be safe? I just want to know if anyone has used this kind safely, not from people who haven't used it at all.
That 3 wheeler looks like an accident waiting to happen. I've got my 383 HP motor on a 4 wheeler from Harbor Freight that works pretty good but it even feels unstable at times depending on how much I try to roll it around in my garage. I wouldn't even try it with that three wheel job. Be careful!
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor 1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic 1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow 1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top 2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue 2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black 2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
[Re: cudabitten]
#1295563
09/02/12 09:01 PM
09/02/12 09:01 PM
Posts: 9,654 Southern by Choice
Shoozy
I have a foot fetish
Southern by Choice
I like many here used one for years for small blocks, lots of 440s and one hemi. As stated use extreme caution when moving it. Think when you are torquing bolts down so you don't tip it. No disasters with mine which eventually got upgraded like Challenger1 suggests - a quick weld job with some scrap tubing and a pair of casters for a four wheeler. You can make it work. And you can NEVER run an engine on that stand.
Old, tired, and sometimes broke down. Me, not my car...
[Re: cudabitten]
#1295566
09/03/12 07:02 AM
09/03/12 07:02 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I have a couple of those HF style stands,but really never use them.I have a Lakewood engine stand(same people that make the bellhousings) that is a 3 wheeler,but very sturdy,and rolls easily with a 440 on it.It's built like a tank.
[Re: 383man]
#1295567
09/03/12 09:50 AM
09/03/12 09:50 AM
cudabitten
eastern, pa.
When I did use that kind I put a 2 x 4 piece of wood from the oil pan to the bottom bar to help support the eng in the front. But that said I had one break on me. We were moving the eng and the wood fell out while pushing it and that fast it broke and the eng fell to the ground. Lucky for me it only hit and cut my foot. It broke off right at the weld. It was cheaply built as the new one we have has a hole in the plate and the round bar goes through the plate and is welded on both sides. It is the kind with four wheels and has the eng tilting down in the back. Ron
Well that did it for me..... I still have the box that it came in and they're open today. I checked out those welds on mine and I don't like them, just three 1/2 welds around that cylinder. If this engine goes over or falls, it'll scare the heck out of me, if it doesn't kill me, and will be a setback to the project. Thanks again.
