Re: TRANSBRAKE NOT HOLDING
[Re: Dragula]
#1295402
09/01/12 09:43 PM
09/01/12 09:43 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
Reverse band would be my guess as well. Is this a fresh build or did it just start doing it. My car starts to creep at about 5500 but I usually leave at 3000-4000. May just be a band adjustment.
[Re: Guitar Jones]
#1295403
09/01/12 10:03 PM
09/01/12 10:03 PM
Posts: 20,189 Park Forest, IL
slantzilla
Park Forest, IL
My Griner is very sensitive to shifter cable adjustment. It doesn't have to be very far off and the brake will not hold.
[Re: bad543dart]
#1295407
09/02/12 10:45 AM
09/02/12 10:45 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
If bypassing the cooler helped? I would check that line pressure.
Leon
[Re: MR_P_BODY]
#1295409
09/02/12 09:53 PM
09/02/12 09:53 PM
Posts: 4,209 New York
polyspheric
New York
X2 Even if there is some other factor in play, it's a good idea to verify you have all the pressure you need for engagement - but not more.
Boffin Emeritus
