How difficult is it to ... #1294906
08/31/12 11:33 PM
08/31/12 11:33 PM
PA - Phila
71GRANCOUPE Offline OP
PA - Phila
Replace a bench seat (73 Charger) with buckets? I am looking at the possibility of either repairing a bench seat (cloth needs to be recovered) or swapping in buckets.
Has anyone done it and how did it turn out -- Pictures?
68 Barracuda Conv
Re: How difficult is it to ... [Re: 71GRANCOUPE] #1294907
08/31/12 11:37 PM
08/31/12 11:37 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Unbolt the bench seat and remove,
Find the dimples in the floor for the buckets,
drill out the proper dimples,
paint holes,
install buckets.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: How difficult is it to ... [Re: amxautox] #1294908
08/31/12 11:40 PM
08/31/12 11:40 PM
Posting from 1893 in NW FL
TheBlueBeast Offline
install re-enforcement pieces of metal to avoid ripping the floor pan out. been there done that.
Re: How difficult is it to ... [Re: TheBlueBeast] #1294909
08/31/12 11:47 PM
08/31/12 11:47 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Plates should be welded to the floor. If that is not an option you need to use plates on top of the floor so the seats don't beat it down and below the floor so you don't rip the seat out under braking.
- Stu Harmon
Re: How difficult is it to ... [Re: feets] #1294910
08/31/12 11:59 PM
08/31/12 11:59 PM
PA - Phila
PA - Phila
Thanks guys -- that helps greatly !!!
68 Barracuda Conv
Re: How difficult is it to ... [Re: 71GRANCOUPE] #1294911
09/01/12 12:02 AM
09/01/12 12:02 AM
Occasionally we actually answer real tech questions. But don't get used to it.
