Max Wedge 1x4 intake #129392
09/29/08 08:24 AM
09/29/08 08:24 AM
San Angelo, Texas, U.S.A.
1968RR Offline OP
1968RR  Offline OP
I love max wedge engines, but I admittedly don't know very much about them. I vaguely remember seeing a single-carb 4 barrel max wedge intake manifold for sale a few years back, but I can't remember the application (NASCAR, maybe) or the casting number.
Does this thing actually exist or am I just crazy?
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Max Wedge 1x4 intake [Re: 1968RR] #129393
09/29/08 08:27 AM
09/29/08 08:27 AM
Gateway to the West.
hemi_harvester Offline
I have seen them also and they where for NASCAR they used to be cheap..don't know anymore....Check the ads in the back of MCG I remember seeing one there for-sale for a long time...
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
Re: Max Wedge 1x4 intake [Re: 1968RR] #129394
09/29/08 08:28 AM
09/29/08 08:28 AM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Yes, they do exist.
Actually there were two designs of the Nascar single 4bbl intake manifolds for the NASCAR Max wedge.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Max Wedge 1x4 intake [Re: hemi71x] #129395
09/29/08 08:36 AM
09/29/08 08:36 AM
hemi71x Offline
hemi71x  Offline
Here's a picture of a 1964 Nascar Max Wedge single 4bbl intake manifold.
Re: Max Wedge 1x4 intake [Re: 1968RR] #129396
09/29/08 09:46 AM
09/29/08 09:46 AM
AndyF Offline
AndyF  Offline
Mopar Performance sells one. Nice intake and not very expensive. Works great with Max Wedge heads on a 440 block. Part number 337
Re: Max Wedge 1x4 intake [Re: AndyF] #129397
09/29/08 10:25 AM
09/29/08 10:25 AM
1968RR Offline OP
1968RR  Offline OP
...good to know I'm not imagining things. I'm getting my Indy-SR heads ported out to MW size soon, and I thought that if I could find one of these things, it might make a nice intake. I realize that there are probably better intakes out there, but having an original MW piece is just kind of special...
2 x 4 MW intakes just seem like a lot of trouble and too much
Thanks for the help.
Re: Max Wedge 1x4 intake [Re: 1968RR] #129398
09/29/08 11:48 AM
09/29/08 11:48 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
the indy dual plane can be easily opened to max wedge port window. in fact the intake is what i'd call a modernized version of the old nascar manifold.
Re: Max Wedge 1x4 intake [Re: lewtot184] #129399
09/29/08 11:52 AM
09/29/08 11:52 AM
1968RR Offline OP
1968RR  Offline OP
I currently have the Indy dual-plane on the motor. It does look really similar...
I was just thinking of maybe going with the MW out of nostalgia.
Re: Max Wedge 1x4 intake [Re: 1968RR] #129400
09/29/08 12:23 PM
09/29/08 12:23 PM
AndyF Offline
AndyF  Offline
If you have Indy heads then just use one of the Indy intakes. Or the Edelbrock Super Victor intake.
The Indy heads use a separate valley plate so you don't need a valley plate on the intake manifold like the Max Wedge intakes have.
The Max Wedge intakes are designed for original Max Wedge heads, not the Indy heads.
Re: Max Wedge 1x4 intake [Re: 1968RR] #129401
09/29/08 02:04 PM
09/29/08 02:04 PM
AndyF Offline
AndyF  Offline
If you put an original (or reproduction) Max Wedge intake on an engine with Indy heads you end up with dual valley trays like this picture.
You could delete the lower valley tray and just build some rail spacers for each end of the valley. That would be the easy solution to run the 337 intake with Indy heads but I think you'll have to build them yourself.
If you build rail spacers they have to be either a two piece design or else they have to be machined with a dovetail cut in each end. I think it would be a bit of a hassle to get it all sealed up properly.
Re: Max Wedge 1x4 intake [Re: AndyF] #129402
09/29/08 03:21 PM
09/29/08 03:21 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
indy makes rail spacers. their dual plane will work with their valley plate too. the indy dual plane actually has max wedge runners that are necked down at the port window. its a no brainer.
