finding bolts for 67 belvedere #1293807
08/29/12 03:31 PM
08/29/12 03:31 PM
louisville ky
67gtxclone Offline OP
louisville ky
does anyone know where i can locate the bolts that attach the power steering box and also all the bolts and nuts for the lower control arms and other front suspension bolts i have a new k member and new steering box but i dont have the necessary hardware to attach them thanks for any help
Re: finding bolts for 67 belvedere [Re: 67gtxclone] #1293808
08/29/12 03:32 PM
08/29/12 03:32 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Any 66-70 B-body (and many other Mopars) used the same hardware. Try your closest junk yard.
Re: finding bolts for 67 belvedere [Re: ScottSmith_Harms] #1293809
08/29/12 03:55 PM
08/29/12 03:55 PM
louisville ky
louisville ky
thanks but i have tried that not many old cars left in this area
Re: finding bolts for 67 belvedere [Re: 67gtxclone] #1293810
08/29/12 09:50 PM
08/29/12 09:50 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
buy new
steering gear box to k-frame bolts
http://www.ebay.com/itm/300762311063?ssPageName=STRK:MEWNX:IT
i just got a set and installed them,perfect!
Re: finding bolts for 67 belvedere [Re: Joesixpack] #1293811
08/29/12 09:54 PM
08/29/12 09:54 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
fyi contact the seller of the bolts, he should be able to hook you up with everything you need....
Re: finding bolts for 67 belvedere [Re: Joesixpack] #1293812
08/29/12 09:57 PM
08/29/12 09:57 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
make a detailed list of what you need and let me know as were building a car right now with all new stuff....might have some older original stuff, ie control arm mounting bolts,etc
Re: finding bolts for 67 belvedere [Re: Joesixpack] #1293813
08/29/12 10:08 PM
08/29/12 10:08 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
Re: finding bolts for 67 belvedere [Re: Joesixpack] #1293814
08/29/12 10:13 PM
08/29/12 10:13 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
http://www.ebay.com/itm/Mopar-67-74-Plym...=item4d03e6a132
used steering gear box mounting bolts, i know Greg and he also can hook you up with other stuff
