Anybody have a set of .040 Cometics on the shelf?
#1293329
08/29/12 01:16 AM
08/29/12 01:16 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
If so, is the middle shim completely flat or does it have a slightly raised area around the bore, same as the outer layers? I know its a weird question, but Id like to know. Thanks ![](/ubbthreads/images/graemlins/thumbs.gif)
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Anybody have a set of .040 Cometics on the shelf?
[Re: 440lebaron]
#1293333
08/29/12 03:50 PM
08/29/12 03:50 PM
Von
NE Oklahoma
Thanx for the info. I have a set of .060s that I no longer need. I do need a .040. I cant see any reason why I cant pull one of the middle .020 shims to give me a .040 stack. But, one of the .020 shims is completely flat, the other has the slight ridge on one side. Im guessing pull the slightly raised shim and keep the flat shim? ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: Von]
#1293334
08/29/12 04:07 PM
08/29/12 04:07 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
Are they new??
I might be able to swap them out for you depending on the bore size. I have new 4.410"'s on the shelf in the thickness you want.
Let me know.
MB
[Re: HPMike]
#1293335
08/29/12 04:11 PM
08/29/12 04:11 PM
Von
NE Oklahoma
Are they new??
No, they were bolted down and ran for about 30 mins, then motor was torn apart.
[Re: Von]
#2009539
02/10/16 10:24 PM
02/10/16 10:24 PM
Von
NE Oklahoma
Old thread...i know. But still wondering about the idea of pulling one of the middle shims to get me at .040.
[Re: Von]
#2009585
02/10/16 11:48 PM
02/10/16 11:48 PM
Posts: 20,206 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Call here and I'm betting they can help you out. They had my Cometic gaskets made and to me FAST, super FAST and they were made to order. http://www.4secondsflat.com/
