Re: 1970 RoadRunner SRT8
[Re: ]
#1292948
12/04/14 11:49 AM
12/04/14 11:49 AM
Posts: 656 Florida
CJD AUTOMOTIVE
It's looking very good. Question - would you do this type of project again?
Yes, but not cheaply!
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
[Re: CJD AUTOMOTIVE]
#1292949
12/04/14 11:53 AM
12/04/14 11:53 AM
Posts: 656 Florida
CJD AUTOMOTIVE
#1292950
12/04/14 11:57 AM
12/04/14 11:57 AM
Posts: 656 Florida
CJD AUTOMOTIVE
BTW, just for my own curiosity, I checked the door gap with a dial caliper before and after mounting on the rotisserie. Didn't change. Box rails and the LX floor structure is stout!
[Re: MileHighDart]
#1292951
12/04/14 04:19 PM
12/04/14 04:19 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Freakin Amazing Build !
You have crazy skills, love it.
Sorry, looking back through and missed your comment. Thanks!!
[Re: mymcodebee]
#1292953
12/31/14 04:15 PM
12/31/14 04:15 PM
Posts: 656 Florida
CJD AUTOMOTIVE
#1292954
01/02/15 08:23 PM
01/02/15 08:23 PM
Posts: 9,116 Falconer, NY
KatFysh
Falconer, NY
![](/ubbthreads/images/graemlins/bow.gif) The tie ins and finish welds are what sucks up all the time.. GREAT job though. Looks like ALOT of fab and fitting for a wheel well... ![](/ubbthreads/images/graemlins/beer.gif) What is the "relief" piece where the black panel meets the red wheel house. The part where you ground it shiney.. circular in shape and a little dished. ![](http://i1060.photobucket.com/albums/t445/340cuda/IMG_2025_zps5e7324f6.jpg) Also, On the 1/4 panel you have "roll lip". Is this for the tire clearance? I thought it looked to fit nicely or are you just getting rid of the sharp edge of the panel so it won't hit the tire sidewall?
When you decide to quit, THAT is the moment when you would've succeeded..
[Re: KatFysh]
#1292955
01/05/15 01:48 PM
01/05/15 01:48 PM
Posts: 656 Florida
CJD AUTOMOTIVE
The black part is the Charger outer wheel house. The shiny part is closing a big hole that is in that piece. I need the factory outers to mount the purge canister in the stock location and wheel speed sensor wiring. The other pieces are just transition pieces to connect to the cut down RR outer wheel house.
Was going to roll the lip with 295's. Not necessary with 275's.
[Re: mymcodebee]
#1292957
01/06/15 12:01 PM
01/06/15 12:01 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Craig. I have been meaning to ask this along the way and just saw a couple photos that show it pretty well. Is the stock width of the LX just slim enough to place the 2" X 4" structural steel rocker ties in between the two cars or did you have to trim the LX to fit them between. They look like they fit pretty well without trimming.
Yep, the LX is actually narrower than the RR. I used 2x5 square tube to tie the two together and "fill" the space in between. The LX floor supports are about 4-3/4" tall from the bottom of the pan to the top of the support, so 5" is what I needed. I didn't really show it, but once I cut open the rocker, I plug welded an 1/8" x 1" wide flat strip to the inside edge of each rocker, top and bottom. Once the 2X5 was welded to the rocker, it has another 1/8" angle welded from the 2x5 to the sill on the inside and on top. That's how you get over 50' of weld, each side!, for installing the box beam.
#1292958
01/07/15 04:50 PM
01/07/15 04:50 PM
Posts: 2,968 Far Northeast.
mymcodebee
Far Northeast.
Thanks Craig I was wondering how it tied together. Thanks again and looking great.
[Re: mymcodebee]
#1292959
01/23/15 07:41 PM
01/23/15 07:41 PM
Posts: 656 Florida
CJD AUTOMOTIVE
[Re: Keepat]
#1805530
04/17/15 12:19 PM
04/17/15 12:19 PM
Posts: 656 Florida
CJD AUTOMOTIVE
[Re: UCUDANT]
#1815559
04/30/15 04:44 PM
04/30/15 04:44 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Amazing workmanship, this is simply a project on a whole other level Thanks! LOVE having this out of the shop for awhile!!
[Re: UCUDANT]
#1817907
05/03/15 07:36 PM
05/03/15 07:36 PM
KatFysh
Falconer, NY
Amazing workmanship, this is simply a project on a whole other level Exactly...That's why I love it soo much..
#1819604
05/05/15 08:35 PM
05/05/15 08:35 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Thanks again guys. It is kinda like a kid to me now, enjoying it being at summer camp, but also anxious to get it back and get it out of the house for good!
