Page 5 of 14 1 2 3 4 5 6 7 13 14
Re: 1970 RoadRunner SRT8 [Re: Force28x] #1292868
05/31/13 01:32 AM
05/31/13 01:32 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
subscribed! I'll be keeping a close eye on this!
Re: 1970 RoadRunner SRT8 [Re: dangina] #1292869
06/01/13 11:34 PM
06/01/13 11:34 PM
houston BC canada
fez340 Offline
fez340  Offline
houston BC canada
ill be watching this for sure! amazing build!
Re: 1970 RoadRunner SRT8 [Re: fez340] #1292870
06/07/13 11:34 PM
06/07/13 11:34 PM
KS
68SportSatvert Offline
KS
AMAZING! What color did you paint the floor and who is the manufacturer and what is the paint code? Thanks!
Re: 1970 RoadRunner SRT8 [Re: 68SportSatvert] #1292871
06/17/13 05:43 PM
06/17/13 05:43 PM
CJD AUTOMOTIVE Offline OP
Just plain old B5 boring (sorry) blue. B5 guys start the hate mail!! I've talked him into a Subaru blue that is very close to B5, will a little more pop, for the outside.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: 1970 RoadRunner SRT8 [Re: CJD AUTOMOTIVE] #1292872
06/17/13 05:45 PM
06/17/13 05:45 PM
Their is like 50 variants of B5. This is Dupont. I don't have the can in front of me, but I can find the variant code if you'd like?
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: 1970 RoadRunner SRT8 [Re: CJD AUTOMOTIVE] #1292873
06/18/13 02:20 PM
06/18/13 02:20 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Definitely one of my favorite builds here I'm way too impatient for that much work though
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 1970 RoadRunner SRT8 [Re: Silver70] #1292874
06/18/13 02:22 PM
06/18/13 02:22 PM
Columbus, Ohio
Chally426 Offline
Chally426  Offline
Columbus, Ohio
Was nice talking to you Craig, sure hope we can work things out as far as my 71 barracuda convert..
Re: 1970 RoadRunner SRT8 [Re: CJD AUTOMOTIVE] #1292875
07/03/13 07:08 PM
07/03/13 07:08 PM
illinois
rapidtransitrick Offline
illinois
surf blue is a nice updated version of the b5 blue
Re: 1970 RoadRunner SRT8 [Re: rapidtransitrick] #1292876
08/12/13 08:51 AM
08/12/13 08:51 AM
The Netherlands, OV
dickdale Offline
dickdale  Offline
The Netherlands, OV
How is it going with this project???
Re: 1970 RoadRunner SRT8 [Re: dickdale] #1292877
10/04/13 05:24 PM
10/04/13 05:24 PM
Started back on this one. You can see I've moved it to the back shop.
Started by prepping the rockers to accept the extension of the frame rail. I pie cut it so I could fully weld the two pieces together
Their is a box channel above the cut that is the inner structure of the RR. I will tie into it.
Just enough room for the window regulator to fully retract. Fully welded sub structure ready for the rear pan.
This is the inner part that I have notched for rail. I've seen others do these cars, recently in Mopar Muscle. I don't want to take anything away from the effort that was put forth, but I'd be concerned with the structure of the cars being built by being skinned. I've studied engineering, but am not an engineer, but understand it. The frame rail section on the LX car is THE integral part of the structure that everything attaches to. It provides the beaming strength of the chassis and transfers the loads front to rear and vice versa. It also is the side impact structure. When they skin these cars, they are cutting away the outer structure of the beam and then using the donor cars 18 gauge rockers to re-complete the beam. That's not ideal. The LX structure is two and 3 layers deep and 14+ gauge. I chose to install the frame beams that attach to the floor sections and to the body. The RR shell does not have to provide the beaming strength for the chassis or vice versa. They do add weight, and I have erred to the side of strength, but I feel it's worth it for safety and chassis rigidity.
Still fitting, but you can see this will attach to the inner structure of the RR.
The rear suspension and jig are what locate the rear floor section. Will post pics when I get that under and start welding this in.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: 1970 RoadRunner SRT8 [Re: CJD AUTOMOTIVE] #1292878
10/04/13 10:59 PM
10/04/13 10:59 PM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Always look forward to seeing your posts and progress pictures.
Can I ask how many cars you've done, or years building them in order to reach this level?
You make it look easy and that only comes with a lot of hours behind it.
I can't afford this. mark
Re: 1970 RoadRunner SRT8 [Re: a12superbee] #1292879
10/07/13 08:24 AM
10/07/13 08:24 AM
Hi Mark,
I've always been building something for 25 years. It always seems the ones that look easy are the hardest. Pictures will always make everything look easy! Look at the build shows on TV. Condense 300 man hours in 30 minutes!
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: 1970 RoadRunner SRT8 [Re: CJD AUTOMOTIVE] #1292880
10/08/13 03:11 AM
10/08/13 03:11 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Quality always shows in the final product, you've done some amazing fab work.
Re: 1970 RoadRunner SRT8 [Re: CJD AUTOMOTIVE] #1292881
10/13/13 07:11 PM
10/13/13 07:11 PM
illinois
illinois
glad this is gaining momentum
Re: 1970 RoadRunner SRT8 [Re: a12superbee] #1292882
10/14/13 09:14 AM
10/14/13 09:14 AM
Thanks, hope to get a block of time towards the end of the month to get back on it. It's amazing that just the few pics ate up 45+ hours.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: 1970 RoadRunner SRT8 [Re: CJD AUTOMOTIVE] #1292883
11/01/13 07:45 PM
11/01/13 07:45 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
Wow very cool build!
Re: 1970 RoadRunner SRT8 [Re: brads70] #1292884
11/06/13 11:11 PM
11/06/13 11:11 PM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
Awesome build. By far the best body swap I've seen. I am doing it the opposite by fitting the Charger into the existing GTX and I thought that was tough!.
Right on with the time....took me 32 hours just to get the steering column to work correct!
Driving modern convenience in classic beauty
Re: 1970 RoadRunner SRT8 [Re: brads70] #1292885
11/07/13 09:22 AM
11/07/13 09:22 AM
Thanks. Going to try and block a week close to Thanksgiving and get this thing rolling.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: 1970 RoadRunner SRT8 [Re: Darius] #1292886
11/07/13 09:36 AM
11/07/13 09:36 AM
Thanks Darius. I've been watching yours as well. Nice job!
I'm sticking firm that this is not a body swap, but rather putting the SRT in the RR. It's probably just semantics, but I feel this maintains the structural integrity much better as the car is built in "layers" and not just a shell welded to a skinned chassis.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: 1970 RoadRunner SRT8 [Re: CJD AUTOMOTIVE] #1292887
11/22/13 05:46 PM
11/22/13 05:46 PM
Falconer, NY
KatFysh Offline
KatFysh  Offline
Falconer, NY
AWESOME.. I was "directed" here from the general section.. duuhh me.. I LOVE what you are doing. Not until about 3 weeks ago did I think of looking at wrecked, newer Gen Challengers for my '70 Barracuda.. NOW, I am watching this post like .. Your Barracuda build is/was excellent..This one REALLY has my attention..
I've taken measurements from a 2010 Challenger but have yet to compare them to my '70. Do you think I'd be better off with a Charger over the Challenger if/when I make up my mind to do this.. I've been around a few welders/torches/grinders/frame jigs etc etc to not be afraid to take something like this on..The final product may not be as award winning as yours but I could hang close..
When you decide to quit, THAT is the moment when you would've succeeded..
