Ex. manifolds- gaskets or no gaskets? #1292271
08/27/12 01:38 PM
08/27/12 01:38 PM
Kewaskum, WI
K
Kelob_pie Offline OP
K
Kewaskum, WI
Hi Guys,
I am going to be putting the stock 440 back into my New Yorker, and I was going to put the exhaust manifolds back on with no gaskets, just like the factory did I believe.
However, my buddy stopped over and he said no way would he do that, he for sure would use gaskets and some high temp RTV.
What works for you guys?
Thanks for any info!
Re: Ex. manifolds- gaskets or no gaskets? [Re: Kelob_pie] #1292272
08/27/12 01:42 PM
08/27/12 01:42 PM
PA
BTTG Offline
BTTG  Offline
PA
I put fel-pro's on my 440. just marked them with a sharpie and then cut out the visible gasket sections with a pair of tinsnips.... best of both worlds factory no gasket appearance as well as good sealing without resurfacing.
Re: Ex. manifolds- gaskets or no gaskets? [Re: Kelob_pie] #1292273
08/27/12 01:46 PM
08/27/12 01:46 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Unless the surfaces are absolutely perfect as they were when fresh machined when new I'd use the gaskets . I use them even after having the manifolds resurfaced .
Re: Ex. manifolds- gaskets or no gaskets? [Re: JohnRR] #1292274
08/27/12 02:01 PM
08/27/12 02:01 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
If all the surfaces are good and clean, you should have no problem with metal to metal contact. I would have a machine shop just take a cleaning swipe to the manifolds and the head surfaces just to be sure. If you must use gaskets, there is only one kind and one kind only for my money. That is the REMFLEX gaskets. All others just don't seal as well as they do. And no RTV or Copper sealer is needed. I am using the REMFLEX with HP manifolds on my 383 Satellite. From the first fire up to all the others I have had no exhaust leaks. Pony up and get the REMFLEX. You won't be disappointed...
Re: Ex. manifolds- gaskets or no gaskets? [Re: CR8CRSHR] #1292275
08/27/12 05:32 PM
08/27/12 05:32 PM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
I would use gaskets for sure. There's no harm. I'm using FelPro with Permatex copper RTV.
I agree, Remflex makes awesome gaskets. I'm using their flange gaskets...absolutely the BEST.
If I had to install new header gaskets, it would be Remflex.
Re: Ex. manifolds- gaskets or no gaskets? [Re: bobs66440] #1292276
08/27/12 05:37 PM
08/27/12 05:37 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I usually spray the exhaust ports on the manifold with hi-temp engine paint, nice/thick, then install them wet and torque in place, and let dry for a day/2 that usually seals them good
Re: Ex. manifolds- gaskets or no gaskets? [Re: DAYCLONA] #1292277
08/29/12 12:47 AM
08/29/12 12:47 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Typically,
I take a 12 inch mill file and knock down any high spots on the manifold, then install with NO gasket...
In 40 years, only one manifold had to come back off for a gasket..
Re: Ex. manifolds- gaskets or no gaskets? [Re: sthemi] #1292278
08/29/12 04:44 AM
08/29/12 04:44 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
NAPA sell a gasket fron VICTOR HEINZ that is made with a lot of graphite that is a lot like the REMFLEX. I have never seen/used a RIMFLEX gasket but I have used the VICTOR HEINZ. gaskets. I am absolutely sold on them. Thet are the only exhaust gasket I will ever use on anything.. .
I am truckless..
Re: Ex. manifolds- gaskets or no gaskets? [Re: 340SHORTY] #1292279
08/29/12 02:33 PM
08/29/12 02:33 PM
Texas
blewbyu2bad Offline
blewbyu2bad  Offline
Texas
Anyone ever use the copper gaskets? Mine is a 340.
Friends Don't Let Friends Drive GM
Re: Ex. manifolds- gaskets or no gaskets? [Re: sthemi] #1292280
08/29/12 04:09 PM
08/29/12 04:09 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Typically,
Me too, I like dayclona idea also if it's a new build, otherwise bare after it's flat.
Re: Ex. manifolds- gaskets or no gaskets? [Re: Challenger 1] #1292281
08/29/12 04:23 PM
08/29/12 04:23 PM
Central IL
70Sbird Offline
70Sbird  Offline
Central IL
Typically,
using the large flat file on both the heads and manifolds is the key to making this work. I also spread a very thin smear of copper RTV on with my finger (same thought as the paint comment above) just for insurance
A little time spent here will go a long way.
Re: Ex. manifolds- gaskets or no gaskets? [Re: 70Sbird] #1292282
08/29/12 08:58 PM
08/29/12 08:58 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Clean with 3M air powered pad. Thin coat of copper RTV and no gaskets. I'm a college drop out, therefore it works for me!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Ex. manifolds- gaskets or no gaskets? [Re: Kelob_pie] #1292283
08/29/12 10:37 PM
08/29/12 10:37 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I spread high temp silicone on the manifold. Let skin. then install and snug up wait 1 hour and tighten good.
