Temp sending unit
#1292229
08/27/12 12:29 PM
08/27/12 12:29 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Hey Gang. I was curious if anyone has a good part number for a Mopar temperature sending unit (gauge) for our older Mopars. I'm putting together my friend's '71 v-code Challenger R/T and asked him to get an OEM sending unit because the ones I've gotten in the past from the local parts store were never accurate or didn't work properly. I ran into this experience for myself on my former '69 Charger 500, hence wishing to get the OEM product. I got back to me and stated that the only thing a local dealership could come up with was a dual-pin sending unit. I told him our era sending units didn't have any "dual-pin"..
Thanks in advance.. T
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: Temp sending unit
[Re: moparjo68]
#1292231
08/27/12 03:28 PM
08/27/12 03:28 PM
hemi68charger
Houston, Tx
I'm guessing you need the temp sender with the single threaded head shaft? Year One has a New Chrysler temp sender that I'm planning on buying when they have their next 30% off sale as their everyday price is 46.99. I had hoped Napa's Echlin temp sender would be of better quality but they were all off, just like all the other aftermarket crap. I would email you the link from Year One but am too dumb. The Year One part number is FD51140.
Nope, that's all good.. I can get there and refer it to my friend, he's been ordering stuff from them anyways... Sooo, I'll just have him add this to the mix....
[Re: moparjo68]
#1292232
08/27/12 04:52 PM
08/27/12 04:52 PM
Posts: 25,988 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Add an "R" to the YO part number and it's only $12...since it's still an FD (Factory Direct) part number I wonder what the difference is.
[Re: John_Kunkel]
#1292233
08/27/12 06:09 PM
08/27/12 06:09 PM
hemi68charger
Houston, Tx
I was hoping someone would have mentioned this, I just didn't know...:)
[Re: hemi68charger]
#1292235
08/27/12 10:08 PM
08/27/12 10:08 PM
Posts: 1,028 NB, Canada
moparfan53
NB, Canada
The 70-71 Chrysler parts book lists the temp sender as part# 2426458. I believe that is superceded to #4051140, which I think is what YO is selling as FD51140 (I have found that sometimes with original Chrysler parts YO replaces the first 2 digits with FD). You could check with your local dealer regarding the number supercession/availability. EDIT: Just did a Google search for #4051140 and RT Speciaties shows it changed to #4504202, so you might want to check that number also at your dealer. http://www.rtspecialties.net/proddetail.asp?prod=4051140
[Re: autoxcuda]
#1292239
08/28/12 11:44 PM
08/28/12 11:44 PM
Posts: 602 N.E.Ohio
pacifica
N.E.Ohio
I heard that Shannon at Redline Gaugeworks says you can add a resistor inline to the aftermarket temp senders to get them to read correctly.
I added a 10 ohm resistor to my temp wire as it goes into the harness near the sender [you don't see it as it is only an inch long]. Solder it in and wrap with tape to match.
I used a parts store sender and it read too high [temp]. Tried a couple resistors and the 10 ohm was correct for my guage to be accurate.
Don't forget to verify your actual water temperature when you try different resistors.
[Re: 62maxwgn]
#1292247
08/31/12 12:02 PM
08/31/12 12:02 PM
Posts: 21,501 It's a dry heat
gtx6970
It's a dry heat
How many do you want ?
Oh,,,,I don't know how about ,,,,, all of them
