Best "Plug-n-Play" SB Distributor? #1292012
08/26/12 10:25 PM
08/26/12 10:25 PM
Glendale, AZ
Dave W Offline OP
Dave W  Offline OP
Glendale, AZ
Couple of questions with money being no object. What's the best performing "plug-n-play" distributor with HEI style terminal cap and using factory style ignition box? What factory style ingnition box is the best? Gold box or the new Rev-n-Nator box? Trying to get the max performance out of my ingnition system while still retaining a some what factory look. Thanks!
Re: Best "Plug-n-Play" SB Distributor? [Re: Dave W] #1292013
08/26/12 10:43 PM
08/26/12 10:43 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Firecore50 is the best one on the market Contact Rick (SunroofGTX) for a distributor,wires,and coil then you are good to go
Gus
64 Plymouth Savoy
Dana 60
Re: Best "Plug-n-Play" SB Distributor? [Re: fourgearsavoy] #1292014
08/26/12 10:56 PM
08/26/12 10:56 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
It really depends on what features you are looking for. I have done some dyno testing of both setups,the RevNNator and the Firecore products. They both perform very well.
If you want a nice distributor call one of the Firecore dealers. You can get a nice one to run with an external box like the RevNNator or a ready to run that does not need an external box.
Keith
