Anyone try aeromotive pump ? #1291871
08/26/12 08:03 PM
08/26/12 08:03 PM
Mt.Vernon ,Ohio
VernMotor Offline OP
Mt.Vernon ,Ohio
http://www.summitracing.com/parts/AEI-11203/
Looks like it would be a real step up from my holley blue.
Re: Anyone try aeromotive pump ? [Re: VernMotor] #1291872
08/26/12 08:33 PM
08/26/12 08:33 PM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
Yes I used to run one a few years back and then ran the A2000 when I switched to ethanol.
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: Anyone try aeromotive pump ? [Re: VernMotor] #1291873
08/26/12 08:39 PM
08/26/12 08:39 PM
in a chair
mopartony Offline
mopartony  Offline
in a chair
Vern,
Those and the Magna-Fuel pumps are so worth the money.
Re: Anyone try aeromotive pump ? [Re: mopartony] #1291874
08/26/12 08:43 PM
08/26/12 08:43 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Well what it cost for me to buy fittings and line to put my other blue pump on. I buy a new pump for less.
Re: Anyone try aeromotive pump ? [Re: VernMotor] #1291875
08/26/12 09:06 PM
08/26/12 09:06 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I run that pump.
Mopar Performance
Re: Anyone try aeromotive pump ? [Re: VernMotor] #1291876
08/26/12 09:43 PM
08/26/12 09:43 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I ran that pump before I went to the Magnafuel 300 pump and it lacked my needed volume BUT, I did bypass it back to the cell w/a 1/2 inch line which may have not been a good idea from what I`ve heard.........I can`t speek highly enuff about my pump and how well it works street/strip so far.........
Re: Anyone try aeromotive pump ? [Re: VernMotor] #1291877
08/26/12 09:46 PM
08/26/12 09:46 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
I ran that pump for 4yrs. no problems at all. switched to magnafuel 300 pump with return and big regulator, no performance increase what so ever. as long as the pump is wired and plumbed correctly should be trouble free
Re: Anyone try aeromotive pump ? [Re: nss guy] #1291878
08/26/12 10:01 PM
08/26/12 10:01 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Did you dead head it?
Re: Anyone try aeromotive pump ? [Re: Thumperdart] #1291879
08/26/12 10:54 PM
08/26/12 10:54 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
I run that pump myself, had it on for I think 4 years, no problems, mine is deadheaded, I have a fuel pressure gauge and it show 7 pounds all the way thru the 1/4, it flows enough to run really low 10's for sure, and I belive quite a bit lower than that, allways seemed to me a lot of people go overkill on fuel pumps. Im feeding two edelbrook 800 cfm, and have also used the pump running two 750 Demons, didnt have a fuel issue with either setup.
Re: Anyone try aeromotive pump ? [Re: wyoming] #1291880
08/26/12 11:03 PM
08/26/12 11:03 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Mine is deadheaded! No issues at all!
But am going to return style setup now.
Mopar Performance
Re: Anyone try aeromotive pump ? [Re: wyoming] #1291881
08/26/12 11:04 PM
08/26/12 11:04 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
As I said, was told they work ok w/a return but have more available volume deadheaded and this proves that point. I finally after many years of racing stepped up and got an "overkill" system and my et`s dropped and mph went up..............the $$$ difference bet. the Mallorys and holley blues and blacks isn`t THAT bad in my opinion and I have zero regrets. I too had 7 lbs. on my gauge but obviously had a "volume" issue having to jet up 8+ sizes just to get the a/f out of the death zone............not any more, now I`m leaning it down and TRYING to level out my fuel curve.
Re: Anyone try aeromotive pump ? [Re: Thumperdart] #1291882
08/27/12 08:18 AM
08/27/12 08:18 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
we will see I guess.... I only have a 1 barrel though... and will control pressure and return after the bowls I will have another 11203 hooked up for backup/spare and more volume if I wanna push more in there
Mopar Performance
Re: Anyone try aeromotive pump ? [Re: moparniac] #1291883
08/27/12 08:31 AM
08/27/12 08:31 AM
pa
572charger Offline
572charger  Offline
pa
9 yrs on my 2 aeromotive pumps ! no problems/ they never give up on the street like the others !! 2 of them ran 2 1050dominators and a 250 hp nos fogger to the tune of 8.93 at 156mph
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Anyone try aeromotive pump ? [Re: 572charger] #1291884
08/27/12 08:45 AM
08/27/12 08:45 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
big chip runs that pump also and he is fast too... dominic must not have had his junk hooked up right or something... several guys faster than him on that pump
nice pass jimmy!
http://www.youtube.com/watch?v=JUPjpF11MIc
Mopar Performance
Re: Anyone try aeromotive pump ? [Re: moparniac] #1291885
08/27/12 08:56 AM
08/27/12 08:56 AM
pa
572charger Offline
572charger  Offline
pa
that was years ago it seems like !! made 2 more at norwalk if it wasnt so darn heavy it would be faster !!
Re: Anyone try aeromotive pump ? [Re: 572charger] #1291886
08/27/12 09:25 AM
08/27/12 09:25 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
I keep forgetting to ask this, but do you have a transbrake, or are you still footbraking it, Jim?
Re: Anyone try aeromotive pump ? [Re: moparniac] #1291887
08/27/12 12:04 PM
08/27/12 12:04 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
nice pass jimmy!
Are we talking the EXACT same pump or the 1000-2000 series? Maybe I got a weak pump but I had to jet WAY up the get the fastest et and best a/f ratio at wot............ Now I`m leaning the carb down and working on the overly rich cruise circuit and it`s getting better and smoother. Yes Sledgie, some are faster than me w/their BIG motors and heads etc.........Little 470 w/crap heads and a medium cam and it`s full potential will be seen in Nov. w/WAY quicket et`s to follow...........TRUST ME! If I had your motor in my car(providing your junk`s hooked up properly) I`d be ashamed to run any slower than 9.40`s n/a in street trim........
Re: Anyone try aeromotive pump ? [Re: Thumperdart] #1291888
08/27/12 12:17 PM
08/27/12 12:17 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
was just funnin' with ya dom ! remember Im 200 pounds heavier so your 9.40's comment at your weight guess my junk don't suck at my weight then ... my junk is setup for nitrous maybe that's why it's so slow and best ET I had was with a 1.44 60ft
Mopar Performance
Re: Anyone try aeromotive pump ? [Re: moparniac] #1291889
08/27/12 12:34 PM
08/27/12 12:34 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Not saying your slow at all just stating; If I had a big motor w/big heads and high-end parts I`d be haulin ass......and my time will come. Now, at my weight w/my crap heads I`m one of the fastest cars here and elsewhere for that matter................
Re: Anyone try aeromotive pump ? [Re: VernMotor] #1291890
08/27/12 05:10 PM
08/27/12 05:10 PM
oh
julian2007 Offline
julian2007  Offline
oh
whats wrong with your holley blue?
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
