yes,installed the trans lever,and bracket for cable on the pan rail.
with eyes on the trans lever,I can move the cable in the truck at the shifter by hand and get play in it but it does not show it moving at the trans.
I have made sure the loop in the cable is not flexing/moveing/burn/scuffed/bent/skined...ect.
it comes thru floor and wraps around back of engine going into the bracket from front of trans.(I talked to you about that when I installed it stumpy and went over adjusting it.)
it did it with the manaul VB and now with a stock VB.
I can get it to shift from 1st to 2nd by shifting the handle 2x,shift from 2nd to 3rd by shifting handle 2x again. I can be in 3rd,pull handle back 1x and nothing again and then it down shifts,same thing going back to 3rd,shift it 2x
when in 3rd,I shift to N and it satys in 3rd till I lift handle and go just a little forward the it goes to N.
I can then pull handle back to N positon and it stays in N.
I lift handle and shift from N to R and stays in N till I go past R a little bit.
I can lift handle and shift from N to park and it locks in park ok.
I have adjusted this a 1/2 turn at a time with the 2 lock nuts at the bracket on the rail pan and have moved the adjuster on the end of cable to trans lever.
exhasted every setting combo I can do for a yr now and only can get it to shift up good or down good but not both. unless I double shift it or use vise grips and feel for it.
I give up, its a sloppy cable is the only thing I can see wrong at this point.
I unhook it from the shift.clamp on a pair of vise grips and shift it by hand/feel and its dead on up or down,but I pull or push the slack out before it ever clicks in/out of the detent.
trans is work good,firm shifts,I have to get this crap fixed so when i get the manaul VB back from CRT the shift is working and adjusted dead on.
I will trade the complete shifter and parts for a good auto shift colum and linakge...oh! wait,i have the linkage not a colum.
![](/ubbthreads/images/graemlins/rolleyes.gif)
I will throw in the small vaise grips I use to shift with at the moment also.
![](/ubbthreads/images/graemlins/thumbs.gif)
does the end of the cable screw on maybe and it needs tightend up?
maybe it the shifter not the cable? toss the shifter and just have a cable with visegrips in the floor???
