Biggest Stroke with Iron World Block and 55MM Cam #1291612
08/26/12 11:52 AM
08/26/12 11:52 AM
Greensburg, Pa
Mpetros Offline OP
Mpetros  Offline OP
Greensburg, Pa
What is the Biggest Stroke that can be used in a Non Raised Cam Iron World?
I want to use 55MM Cam with Aluminum Rods
Re: Biggest Stroke with Iron World Block and 55MM Cam [Re: Mpetros] #1291613
08/26/12 12:05 PM
08/26/12 12:05 PM
reynoldsburg,ohio
poppaj Offline
poppaj  Offline
reynoldsburg,ohio
4.625 best bet. You can use a 4.75 but rods have to be profiled on big end, gives up a lot of metal/strength. Most generally a small baseline cam as well. With a 4.5 bore the 4.625 gives you a 588cu.in. mill. Believe me this is a much nicer combo vs the 4.5x4.75=604cu.in.poppaj
AA/NSS 65'Coronet "Whompin Wedge"
Pop & Son Performance 557" B-1 power
John Holt Chassis
Re: Biggest Stroke with Iron World Block and 55MM Cam [Re: poppaj] #1291614
08/28/12 09:29 PM
08/28/12 09:29 PM
Greensburg, Pa
Mpetros Offline OP
Mpetros  Offline OP
Greensburg, Pa
So the 4.625 clears the 55MM Cam with out Cam cutting the Rods?
Re: Biggest Stroke with Iron World Block and 55MM Cam [Re: Mpetros] #1291615
08/28/12 10:24 PM
08/28/12 10:24 PM
Delray beach, Florida
P
Performance Only Offline
P
i wouldn't bet on it, how big is the cam and which brand of connecting rod?
machine shop owner and engine builder
Re: Biggest Stroke with Iron World Block and 55MM Cam [Re: Mpetros] #1291616
08/28/12 10:48 PM
08/28/12 10:48 PM
What rod journal size, 2.375, 2.200, 2.? or 1.88
Re: Biggest Stroke with Iron World Block and 55MM Cam [Re: Cab_Burge] #1291617
08/29/12 12:00 AM
08/29/12 12:00 AM
Greensburg, Pa
Mpetros Offline OP
Mpetros  Offline OP
Greensburg, Pa
Cam Motion Cam, Not sure on lift yet..GRP Rods with 2.2 Chevy size
