Do I need a residual valve? #1291398
08/25/12 11:23 PM
08/25/12 11:23 PM
in front of the computer
8
80arrow Offline OP
80arrow  Offline OP
I bit the bullet and am putting new disc brakes on all four corners of my Dart. I bought a residual valve for it but in its instructions it says you only need it if the master cylinder is lower then the rear brakes. My m/c is in the stock location, so do I need to use it? Thanks, Clint
Re: Do I need a residual valve? [Re: 80arrow] #1291399
08/25/12 11:36 PM
08/25/12 11:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No
Re: Do I need a residual valve? [Re: MR_P_BODY] #1291400
08/25/12 11:38 PM
08/25/12 11:38 PM
8
80arrow Offline OP
80arrow  Offline OP
Thank you, that makes life a little easier.
