Won't stay running- I don't have a clue
#1291340
08/25/12 08:00 PM
08/25/12 08:00 PM
Posts: 1,173 Central Louisiana
jim
Central Louisiana
OK, we have a little show and shine this evening so I got the Dart out and gave her a bath, spiffed all up and ready to go. I had driven her over to the area where I wash the cars, no problem. But when I jumped in to go, it would start and die, start and die, as soon as I turn the key to star position, the 360 cranks over, she fires up and I let go of the key and it dies as soon as the key returns to the run position. I checked fuel, OK. then I notice that as soon as I let the key return to run the amp guage jumps to the far right, showing a high charge rate, as it dies. Then I crank it and it starts, then as the key returns to run, the engine dies, but if I bring the key back to start position, it will fire back up. Seems like it will run in the start position but not in the run position. So do I have a problem with the key switch or somewhere else. Or did I make any sense at all of this whole thing?
Re: Won't stay running- I don't have a clue
[Re: jim]
#1291343
08/25/12 08:22 PM
08/25/12 08:22 PM
RapidRobert
Pull the yellow wire off of the starter relay to disable the starter. Have a helper hold the key to start. you under the hood with a VOM & see if the coil positive primary terminal and the ECU are getting fire & if not work back upstream to the ballast connector and the bulkhead then inside to the ign switch if need be to find the open
[Re: stumpy]
#1291348
08/26/12 12:10 AM
08/26/12 12:10 AM
Posts: 5,450 So Cal
Sinitro
So Cal
I don't think you use a ballast with MSD. If not then turn thr key to the run position and see if you have 123v to the coil. If not then back track the + coil wire to the ignition switch to see if it is not broken. Some times it can be bad at the bulkhead or at the plug at the column.
123V to the coil.. That'll blow it out for sure.. I think you mean 12V...
Just my $0.02..
[Re: Sinitro]
#1291351
08/26/12 12:53 PM
08/26/12 12:53 PM
Posts: 33,012 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
Just my $0.02..
What,you don't believe in a hot spark? Just a case of fat finger thank you very much.
