Page 3 of 4 1 2 3 4
Re: 800psi enough for manual disc brakes ? [Re: feets] #1290796
09/08/12 09:11 PM
09/08/12 09:11 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Re: 800psi enough for manual disc brakes ? *DELETED* [Re: jcc] #1290797
09/08/12 09:47 PM
09/08/12 09:47 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Post deleted by 70Cuda383
- Stu Harmon
Re: 800psi enough for manual disc brakes ? [Re: feets] #1290798
09/11/12 12:00 PM
09/11/12 12:00 PM
Ontario,Canada
firefighter3931 Offline OP
Ontario,Canada
Just an update :
Bedded in the new Hawk HPS pads and happy to report the car stops great...night & day difference !
I feel confident taking it to the track now and being able to slow down from 125+ MPH. Before it felt like a drum brake setup that was overheating and into severe brake fade.
To summarize ; I left the prop valve wide open. No premature lockup on the rear brakes.
Ron
Re: 800psi enough for manual disc brakes ? [Re: firefighter3931] #1290799
09/11/12 12:23 PM
09/11/12 12:23 PM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
(Brador!)
Re: 800psi enough for manual disc brakes ? [Re: firefighter3931] #1290800
09/12/12 08:55 AM
09/12/12 08:55 AM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Congrats on getting it fixed!!!
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: 800psi enough for manual disc brakes ? [Re: Uhcoog1] #1290801
09/13/12 07:51 AM
09/13/12 07:51 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
OK, I cleaned this back up a little to keep it on topic. everyone's had their fun, time to get back on topic.
**Photobucket sucks**
Re: 800psi enough for manual disc brakes ? [Re: 70Cuda383] #1290802
09/13/12 12:48 PM
09/13/12 12:48 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Great! Now the mods are acting like jcc and exerting their authority.
- Stu Harmon
Re: 800psi enough for manual disc brakes ? [Re: feets] #1290803
09/16/12 08:30 AM
09/16/12 08:30 AM
Hamburg / Germany
Den300 Offline
Den300  Offline
Hamburg / Germany
@firefighter3931/Ron: I have the same set up and have the same problems.
So I would like to change to the hawk pads too.
Could you tell me the exact part number? thanks!
Dennis
Hamburg/Germany
69 Chrysler 300
446cui Dual Quad
12.64 @ 110.7
Re: 800psi enough for manual disc brakes ? [Re: 70Cuda383] #1290804
09/18/12 12:15 AM
09/18/12 12:15 AM
Washington State, USA
W
Winchester 73 Offline
W
An 11 inch rotor for a 4000 lb car is just asking for trouble. No one would design a system like that anymore. Go visit a car lot and look at 4000 lb cars with 300+ hp engines. They'll all have 13 inch or 14 inch rotors.
Funny you should mention it... Up through '02, the 4,000+ lb Dakota's and Durangos had 11" rotors and tiny, single piston calipers. And it's no secret the brakes sucked on them!
dont feel bad my brother in laws tahoe has smaller rotors than the cordoba brakes on my dart!looks even more stupid with 26' rims
Barely enough for one 55 mph panic stop.
Re: 800psi enough for manual disc brakes ? [Re: Den300] #1290805
09/18/12 11:22 AM
09/18/12 11:22 AM
Ontario,Canada
Ontario,Canada
Dennis
Hi Dennis, the Hawk HPS pad for the SS Brake 4 piston caliper is : HB471F-510
http://www.summitracing.com/parts/HWK-HB471F-510/Application/?prefilter=0
The plate number is D11 which fits several Dodge/Plymouth & Ford factory calipers.
Happy to report the brakes worked great at the track stopping from 120+ MPH. The raceweight is 4200lbs so it's no lightweight, lol !
Make sure you adjust the prop valve wide open and adjust from there. Clockwise opens the valve, fyi
Ron
Re: 800psi enough for manual disc brakes ? [Re: Winchester 73] #1290806
09/18/12 11:27 AM
09/18/12 11:27 AM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
We should all be dead by now!
The biggest problem is keeping the sheet metal straight when driving in traffic these days.
Re: 800psi enough for manual disc brakes ? [Re: Uhcoog1] #1290807
09/18/12 11:28 AM
09/18/12 11:28 AM
Ontario,Canada
Ontario,Canada
Thanks ! Feels much better now and stops great !
Next problem ; traction
Need to play with the cal-tracs The 572 is blowing the M/T Drag radials off even with a descent burn out and well prepped track
Ron
Re: 800psi enough for manual disc brakes ? [Re: @#$%&*!] #1290808
09/18/12 01:00 PM
09/18/12 01:00 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
In the past it wasn't an issue. Everybody's brakes sucked by comparison.
Now you have SUVs that can stop shorter than many old muscle cars. That means the old car has become the hazard.
- Stu Harmon
Re: 800psi enough for manual disc brakes ? [Re: firefighter3931] #1290809
09/18/12 02:56 PM
09/18/12 02:56 PM
Hamburg / Germany
Den300 Offline
Den300  Offline
Hamburg / Germany
Ron
Thanks Ron! I also will play a little bit with the prop valve.
I also always thought it is just to reduce rear brake pressure. but
its worth a try to "close" the rear to see if I also can increaswe front pressure.
And its even heavier 4400lbs in race trim
Re: 800psi enough for manual disc brakes ? [Re: feets] #1290810
09/18/12 09:34 PM
09/18/12 09:34 PM
Thigh-Gap Junction
@#$%&*! Offline
@#$%&*!  Offline
Thigh-Gap Junction
That's what I was trying to say, thanks for the clarification.
Re: 800psi enough for manual disc brakes ? [Re: firefighter3931] #1290811
09/23/12 04:51 PM
09/23/12 04:51 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
A 1" MC piston is too large for manual brakes unless the front caliper pistons are large. You did not mention pedal ratio. You need at least 6-1 with manual brakes.
Re: 800psi enough for manual disc brakes ? [Re: Lefty] #1290812
10/20/12 01:15 PM
10/20/12 01:15 PM
Hamburg / Germany
Den300 Offline
Den300  Offline
Hamburg / Germany
Short update:
I bought me the EBC yellow stuff brake pads for my SSBC force 10 kit
as the Hawk pads cost roughly 50% more here in Germany.
Even though I drove only 15mls today and the brake-in procedure is not finished
I can say right now that it is a huge improvement over the SSBC pads!
Next step is to play with the prop valve. Maybe I see the same results as Ron.
Dennis
Hamburg/Germany
69 Chrysler 300
446cui Dual Quad
12.64 @ 110.7
Re: 800psi enough for manual disc brakes ? [Re: Den300] #1290813
11/16/12 07:32 PM
11/16/12 07:32 PM
Ontario,Canada
Ontario,Canada
Thanks for the update Dennis
Good to hear the EBC pads helped....i'm sure they're better than the SSBC pads that come with the kit.
Ron
Re: 800psi enough for manual disc brakes ? [Re: firefighter3931] #1290814
10/31/13 04:24 PM
10/31/13 04:24 PM
Hamburg / Germany
Den300 Offline
Den300  Offline
Hamburg / Germany
Short update on the brakes.
Today I´ve been at the technical inspection.
Last time they measured 300 deca newton for the front brakes.
I changed the stock SSBC pads with EBY Yellowstuff and now they
measured 350 deca newton. that is roughly 17% more stopping power.
Not too bad for a pad change. Real improvment and the first time
I reached more clamping power at the front than at the rear (330daN).
Hamburg/Germany
69 Chrysler 300
446cui Dual Quad
12.64 @ 110.7
Re: 800psi enough for manual disc brakes ? [Re: Den300] #1290815
10/31/13 07:01 PM
10/31/13 07:01 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
I've been using EBC Yellow pads in my Viper calipers( manual M/C) for a couple of years now. They work good, not the greatest cold but REALLY work better when hot! No more brake fade!
Page 3 of 4 1 2 3 4
