Page 4 of 4 1 2 3 4
Re: 800psi enough for manual disc brakes ? [Re: brads70] #1290816
11/01/13 06:20 AM
11/01/13 06:20 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
On my own Dart I've recently replaced a set of old stock metallic pads for a set of Hawk HPS pads and the difference is verry noticable at moderate to high speeds. Not so much at low speeds with less pedalpressure.
I also think these pads get better when warmed up a bit. The first few brake stops in the morning aren't that impressive.
The previous pads (found on a old car), while braking was OK, mainly did a good job of polishing the rotors to a mirror shine, while the HPS pads now leave a mat finish on the rotors, also telling me they're doing a better job of grabbing the rotor.
Re: 800psi enough for manual disc brakes ? [Re: BigBlockMopar] #1290817
11/01/13 06:38 AM
11/01/13 06:38 AM
Hamburg / Germany
Den300 Offline
Den300  Offline
Hamburg / Germany
I noticed the same. The yellow stuff pads srubbed more off the rotors within 600miles
than the ssbc ones within 4 years! They also get better when they are warm.
Hamburg/Germany
69 Chrysler 300
446cui Dual Quad
12.64 @ 110.7
Re: 800psi enough for manual disc brakes ? [Re: Den300] #1290818
11/01/13 09:15 AM
11/01/13 09:15 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Once you guys get some miles on these set-ups, I'd like to know what your rotor life is like with these more aggressive pads.
**Photobucket sucks**
Re: 800psi enough for manual disc brakes ? [Re: 70Cuda383] #1290819
11/01/13 02:15 PM
11/01/13 02:15 PM
The Netherlands
The Netherlands
I drive my car daily.
Although I don't travel a lot of miles every week due to the short local distances in my country, my car does do a lot of stop&go driving.
Re: 800psi enough for manual disc brakes ? [Re: 70Cuda383] #1290820
11/01/13 09:57 PM
11/01/13 09:57 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
Had mine on for 3 seasons now, so far so good. I drive it to Carlisle every year and lots of local shows. Take it out almost daily if weather is good. I'm going to get a set for the rear brakes too as I found while doing the Hotchkis autocross thing at Carlisle the fronts lock up way before the rears when they get hot.
Re: 800psi enough for manual disc brakes ? [Re: brads70] #1290821
07/03/14 04:45 PM
07/03/14 04:45 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
I'm bringing this thread up from the dead because I am having the same issue, but for a seemingly different reason.
I am also running a proportioning valve in my rear brake line and I thought that the original poster's fix would be a "voila" moment for me, but no amount of proportioning valve adjustment will give me more than 800psi to the front brakes. The rear brakes are also at 800 psi when allowed to get full flow from the valve.
I have played with the pedal ratio. The stock M/C pickup point is 1.5" below the pivot. The hole I drilled is 2.125" below.
The lower hole has a lower ratio, yet that's where I get the best pedal and pressure.
The problem with using the upper hole is that the brake pedal has a super long throw, and it barely makes 500lbs before hitting the floor.
When I do the calculations I get 7.6:1 for the top hole and 5.4:1 for the bottom.
Any suggestions? I'm ready to pull out what little hair I have left
BTW, this setup is in a '60 Dart. I am running '99 Ram front calipers and '04 Cobra calipers in the rear with a Wilwood 7/8" M/C.
Re: 800psi enough for manual disc brakes ? [Re: PolyDart] #1290822
07/03/14 09:35 PM
07/03/14 09:35 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
What is the diameter of the piston(s) in the front and rear calipers?
How many piston in each caliper?
Re: 800psi enough for manual disc brakes ? [Re: autoxcuda] #1290823
07/03/14 11:15 PM
07/03/14 11:15 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
More leverage and more pedal travel equals less line pressure? You sure ALL the air is out?
Re: 800psi enough for manual disc brakes ? [Re: autoxcuda] #1290824
07/04/14 01:29 AM
07/04/14 01:29 AM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
I called Wilwood shortly after posting this afternoon. He asked about the calipers as well.
He's telling me that a 1" bore M/C would be more appropriate for the size pistons I'm running in the Dodge Ram calipers. He said I'm running out of volume and that's why the pedal is catching so low no matter which hole I put the M/C pushrod.
Re: 800psi enough for manual disc brakes ? [Re: PolyDart] #1290825
07/04/14 05:34 PM
07/04/14 05:34 PM
The Netherlands
The Netherlands
That's 40% more pedalwork you're able to push now.
I'm pretty sure you need to go up in size on the MC again a bit to get the proper fluid-displacement and prevent the pedal from bottoming out.
Re: 800psi enough for manual disc brakes ? [Re: PolyDart] #1290826
07/05/14 12:40 PM
07/05/14 12:40 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Yep!
You've run out of master cylinder.
Dig up the brake math spreadsheet and crunch some numbers. I don't have the specs on the calipers but you can probably grab them from product info on Rock Auto.
- Stu Harmon
Re: 800psi enough for manual disc brakes ? [Re: feets] #1290827
07/05/14 03:14 PM
07/05/14 03:14 PM
upper So. CA
N
ntsqd Offline
ntsqd  Offline
N
upper So. CA
For manual brakes I shoot for 93:1 to 95:1 total system ratio for the fronts. then tune in the rears as needed. That is hydraulic ratio multiplied by pedal ratio. Can go over 95:1, but go under 93:1 at your own peril. Below 93 the pedal will rapidly trend towards being rock hard with low line pressure. Above ~100:1 will definitely feel 'mushy.'
I used to swerve around my hallucinations, now I drive right thru them.
Page 4 of 4 1 2 3 4
