Re: 800psi enough for manual disc brakes ?
[Re: feets]
#1290796
09/08/12 09:11 PM
09/08/12 09:11 PM
Posts: 22,772 Bitopia
jcc
Bitopia
Re: 800psi enough for manual disc brakes ? *DELETED*
[Re: jcc]
#1290797
09/08/12 09:47 PM
09/08/12 09:47 PM
Posts: 28,076 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Post deleted by 70Cuda383
[Re: feets]
#1290798
09/11/12 12:00 PM
09/11/12 12:00 PM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
Just an update : Bedded in the new Hawk HPS pads and happy to report the car stops great...night & day difference ! I feel confident taking it to the track now and being able to slow down from 125+ MPH. Before it felt like a drum brake setup that was overheating and into severe brake fade. To summarize ; I left the prop valve wide open. No premature lockup on the rear brakes. Ron
[Re: firefighter3931]
#1290800
09/12/12 08:55 AM
09/12/12 08:55 AM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
Congrats on getting it fixed!!!
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: Uhcoog1]
#1290801
09/13/12 07:51 AM
09/13/12 07:51 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
OK, I cleaned this back up a little to keep it on topic. everyone's had their fun, time to get back on topic.
**Photobucket sucks**
[Re: feets]
#1290803
09/16/12 08:30 AM
09/16/12 08:30 AM
Posts: 214 Hamburg / Germany
Den300
Hamburg / Germany
@firefighter3931/Ron: I have the same set up and have the same problems. So I would like to change to the hawk pads too. Could you tell me the exact part number? thanks!
Dennis
Hamburg/Germany
69 Chrysler 300 446cui Dual Quad 12.64 @ 110.7
[Re: 70Cuda383]
#1290804
09/18/12 12:15 AM
09/18/12 12:15 AM
Posts: 168 Washington State, USA
Winchester 73
An 11 inch rotor for a 4000 lb car is just asking for trouble. No one would design a system like that anymore. Go visit a car lot and look at 4000 lb cars with 300+ hp engines. They'll all have 13 inch or 14 inch rotors.
Funny you should mention it... Up through '02, the 4,000+ lb Dakota's and Durangos had 11" rotors and tiny, single piston calipers. And it's no secret the brakes sucked on them!
dont feel bad my brother in laws tahoe has smaller rotors than the cordoba brakes on my dart!looks even more stupid with 26' rims
Barely enough for one 55 mph panic stop.
[Re: Den300]
#1290805
09/18/12 11:22 AM
09/18/12 11:22 AM
firefighter3931
Ontario,Canada
Dennis
Hi Dennis, the Hawk HPS pad for the SS Brake 4 piston caliper is : HB471F-510
http://www.summitracing.com/parts/HWK-HB471F-510/Application/?prefilter=0
The plate number is D11 which fits several Dodge/Plymouth & Ford factory calipers.
Happy to report the brakes worked great at the track stopping from 120+ MPH. The raceweight is 4200lbs so it's no lightweight, lol !
Make sure you adjust the prop valve wide open and adjust from there. Clockwise opens the valve, fyi
Ron
[Re: Winchester 73]
#1290806
09/18/12 11:27 AM
09/18/12 11:27 AM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
We should all be dead by now!
The biggest problem is keeping the sheet metal straight when driving in traffic these days.
[Re: Uhcoog1]
#1290807
09/18/12 11:28 AM
09/18/12 11:28 AM
firefighter3931
Ontario,Canada
Thanks ! Feels much better now and stops great !
Next problem ; traction
Need to play with the cal-tracs The 572 is blowing the M/T Drag radials off even with a descent burn out and well prepped track
Ron
[Re: feets]
#1290810
09/18/12 09:34 PM
09/18/12 09:34 PM
Thigh-Gap Junction
In the past it wasn't an issue. Everybody's brakes sucked by comparison. Now you have SUVs that can stop shorter than many old muscle cars. That means the old car has become the hazard.
That's what I was trying to say, thanks for the clarification.
[Re: Lefty]
#1290812
10/20/12 01:15 PM
10/20/12 01:15 PM
Den300
Hamburg / Germany
Short update: I bought me the EBC yellow stuff brake pads for my SSBC force 10 kit as the Hawk pads cost roughly 50% more here in Germany. Even though I drove only 15mls today and the brake-in procedure is not finished I can say right now that it is a huge improvement over the SSBC pads! Next step is to play with the prop valve. Maybe I see the same results as Ron. Dennis
Hamburg/Germany
#1290814
10/31/13 04:24 PM
10/31/13 04:24 PM
Den300
Hamburg / Germany
Short update on the brakes.
Today I´ve been at the technical inspection. Last time they measured 300 deca newton for the front brakes. I changed the stock SSBC pads with EBY Yellowstuff and now they measured 350 deca newton. that is roughly 17% more stopping power. Not too bad for a pad change. Real improvment and the first time I reached more clamping power at the front than at the rear (330daN).
Hamburg/Germany
