how to attach throttle cable to new holley carb? #1290429
08/23/12 11:43 PM
08/23/12 11:43 PM
Warren, MI
Jerry Offline OP
Jerry  Offline OP
Warren, MI
i've got a new holley on my 383 and its an auto trans challenger. so i'm trying to keep the car looking mostly stock so i don't want any billet brackets, gawdy carb mounted brackets etc. i know holley sells a bracket that bolts to the carb but i can't see how that would work. so i'
m open to suggestions and pictures as i'm trying to achieve the close to stock look.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: how to attach throttle cable to new holley carb? [Re: Jerry] #1290430
08/24/12 12:02 AM
08/24/12 12:02 AM
AndyF Offline
AndyF  Offline
Not sure I understand what the problem is. The throttle cable just attaches to the throttle stud on the carb. Do you need a taller throttle bracket? Have you looked at the brackets that Mancini Racing and Hughes Engines sell?
Re: how to attach throttle cable to new holley carb? [Re: AndyF] #1290431
08/24/12 12:11 AM
08/24/12 12:11 AM
Warren, MI
Jerry Offline OP
Jerry  Offline OP
Warren, MI
i am keeping the stock air cleaner and my throttle cable and kickdown and offset closer to the valve cover. plsu my throttle calbe won't reach where i'm thinking of attaching the stud on the carb. i see holley sells a bracket thats specially designed for the chrysler pull stud, to relocate it back to where the factory had it.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: how to attach throttle cable to new holley carb? [Re: Jerry] #1290432
08/24/12 10:02 AM
08/24/12 10:02 AM
Maryland
mrob Offline
mrob  Offline
Maryland
Maybe you're talking about this part?
http://www.holley.com/20-7.asp
You bolt this part to the the Holley throttle lever and then bolt your old throttle lever stud to it. As you already know, your throttle cable connects to the throttle lever stud.
Re: how to attach throttle cable to new holley carb? [Re: mrob] #1290433
08/24/12 11:09 AM
08/24/12 11:09 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Yep that's the part the OP needs to get the cable to have the correc angle from the carb to the throttle cable holding bracket at the rear of the engine. Had to purchase one for each of my Holley carbs for the 383 and 440, and the kickdown pin for the 727 on the 383 carb. Simple and eazy bolt on bracket and pin and well worth the money. I think my local Advance Auto Parts store had it in stock or got it in a few hours (next day at the most?) just give them the Holley part numbers.
Re: how to attach throttle cable to new holley carb? [Re: A12] #1290434
08/24/12 12:13 PM
08/24/12 12:13 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
went out and took this pic just for you-on my 400, no kick down though(manual valve body), non factory throttle cable(spectre)-
Re: how to attach throttle cable to new holley carb? [Re: 65rbdodge] #1290435
08/24/12 01:38 PM
08/24/12 01:38 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Yup,,, you gotta have it...
I am truckless..
Re: how to attach throttle cable to new holley carb? [Re: 65rbdodge] #1290436
08/24/12 01:38 PM
08/24/12 01:38 PM
AndyF Offline
AndyF  Offline
If you don't have the kick down linkage then you don't really need that extra adapter.
Re: how to attach throttle cable to new holley carb? [Re: Jerry] #1290437
08/24/12 09:22 PM
08/24/12 09:22 PM
Shoreline, Washington
72roadrunnergtx Offline
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: how to attach throttle cable to new holley carb? [Re: 72roadrunnergtx] #1290438
08/25/12 12:31 PM
08/25/12 12:31 PM
Warren, MI
Jerry Offline OP
Jerry  Offline OP
Warren, MI
alright, i got one ordered at my local oriellys came in yesterday, just haven't had time to pick it up.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
