HEMI heads? #1290331
08/23/12 09:33 PM
08/23/12 09:33 PM
Indiana
79_W200 Offline OP
79_W200  Offline OP
Indiana
Going to build new engine for the pulling truck over the winter considering going to hemi what heads would be best for these rules
9. Engine must be naturally aspirated. Any single four-barrel carb allowed with any cast aluminum intake manifold, No sheet metal intakes. 470 cubic inch or 58.75 per cylinder. Gasoline only, Cast iron block, any cast iron heads. Aluminum heads that meet the following criteria are allowed.
a.) OEM intake port locations
b.) Accepts OEM production valvetrain
c.) Exhaust ports can only be raised a maximum of 5/8" of an inch.
1979 W200 470
Re: HEMI heads? [Re: 79_W200] #1290332
08/23/12 10:09 PM
08/23/12 10:09 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Stave V, replacement heads CNC by tim banning would meet your needs. Tim
Re: HEMI heads? [Re: 79_W200] #1290333
08/23/12 11:28 PM
08/23/12 11:28 PM
tn
robnbird Offline
robnbird  Offline
tn
Not Indy !!!!!! go with stage v you will be glad you did.
Re: HEMI heads? [Re: robnbird] #1290334
08/24/12 12:32 AM
08/24/12 12:32 AM
ONTARIO,CANADA
604 Hemi GTX Offline
ONTARIO,CANADA
Not to hijack, but what type of problems did you have with the indy heads?
Kevin
Kevin
Re: HEMI heads? [Re: 604 Hemi GTX] #1290335
08/24/12 12:42 AM
08/24/12 12:42 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Do a search, quality control issues/poor customer service. Tim
Kevin
Kevin
Re: HEMI heads? [Re: astjp2] #1290336
08/24/12 06:47 AM
08/24/12 06:47 AM
Cincinnati OH
Bishop Offline
Bishop  Offline
Cincinnati OH
I would go with the Stage V Custom head with raised exhaust ports and have Jeff @ MCH in MI CNC port them! As far as the single 4 BBL cast intake goes I think the Ray Barton 4500 should work well.
Brian
Re: HEMI heads? [Re: Bishop] #1290337
08/24/12 09:52 AM
08/24/12 09:52 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
The Stage V replacement head will be enough and I agree the Ray Barton intake probably makes the most power.
2011 Drag Pak Challenger
Re: HEMI heads? [Re: rickseeman] #1290338
08/24/12 12:51 PM
08/24/12 12:51 PM
Indiana
79_W200 Offline OP
79_W200  Offline OP
Indiana
What is the limit on the iron replacement heads? if i can keep it cast iron it opens up some other clubs with a rule of any cast iron head allowed.
1979 W200 470
Re: HEMI heads? [Re: 79_W200] #1290339
08/24/12 01:29 PM
08/24/12 01:29 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
No limit
JAKES AUTOMOTIVE
Re: HEMI heads? [Re: 79_W200] #1290340
08/24/12 01:35 PM
08/24/12 01:35 PM
AndyF Offline
AndyF  Offline
If you can afford the money then buy a set of Super Stock cast iron heads. Those should fit the rules. That would be really expensive for new heads, but you might be able to find some older heads that aren't competitive in SS any more. I'm sure some of the NHRA guys have stacks of older heads on the shelf.
If you don't want to go that way then the easy thing would be to call up Tim and order a CNC set of the Stage V heads. I have a set of those sitting here in the shop and they look great.
Re: HEMI heads? [Re: AndyF] #1290341
08/24/12 02:29 PM
08/24/12 02:29 PM
Indiana
79_W200 Offline OP
79_W200  Offline OP
Indiana
Can the stock heads with a 470 limit make around 900-950
1979 W200 470
Re: HEMI heads? [Re: 79_W200] #1290342
08/24/12 03:19 PM
08/24/12 03:19 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I have a NOS set of cast iron D-4's. (I would assume the last NOS set there is.) The D-4's were NASCAR heads, larger intake ports and raised D exhaust ports. They were Chrysler's highest horsepower heads for the 426. I would sell them for $3,000. Rick 501-519-7425
Re: HEMI heads? [Re: rickseeman] #1290343
08/24/12 04:11 PM
08/24/12 04:11 PM
Todd Marsh and his engine guy have built the winningest engine in that class that was ever done--The customer had won 4-5 years in a row, national Champ, and I did his engine one year--he won another national Champ then the Fords caught up with them so he went to Todd with a good budget--they built a MONSTER CI limited combo--big bore shortest stroke possible--it KILLED the other guys and has won several more national Championships--Call Todd at Moparts Connection--NO he will not build it for you free over the phone with all his tips--Yes he will do it for you and promise you wins--Wheel speed is everything in that game--Call him, start winning!
Oh yea, go by the bank first and remember to stick with a builder that has a winning rep at truck pulling--it ain't dragging for sure!
Re: HEMI heads? [Re: ] #1290344
08/26/12 02:20 PM
08/26/12 02:20 PM
Indiana
79_W200 Offline OP
79_W200  Offline OP
Indiana
Is it possible to get in the 900-950 range in hp with the iron heads if so this keeps me from any argument since any iron heads allowed.
1979 W200 470
Re: HEMI heads? [Re: ] #1290345
08/26/12 03:19 PM
08/26/12 03:19 PM
tn
robnbird Offline
robnbird  Offline
tn
well you can buy your mopar parts from todd also I have bought several parts from todd and he is excellent to deal with . Just down to earth and honest . Also Todd doesn't try to put on the act, like a mad scientist who has been nabbed by aliens and returned with extra terrestial mechanical knowlege
Re: HEMI heads? [Re: 79_W200] #1290346
08/26/12 07:30 PM
08/26/12 07:30 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Iron heads will do the # you want.
Sheldon
Re: HEMI heads? [Re: RUNCHARGER] #1290347
08/27/12 05:06 AM
08/27/12 05:06 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
In your first post you said you were thinking about a hemi. Imo you should think about budget first which you haven't mentioned and if you as stated earlier have not gone to your banker first you may reconsider. You said iron heads would be easier because it opens up more clubs to you. This statement leads me to believe this this is not a National level truck. My point is at that cubic inch and rules the guys around here use cast iron indy-1s if you have a modest budget. Diablo (on this forum) ran them for quite a while with good success.
Don't know about the mopar hemis but the ford pulling hemis are 40-50 K. Like I said just another pullers opinion.
Re: HEMI heads? [Re: mac56] #1290348
08/27/12 06:52 AM
08/27/12 06:52 AM
Indiana
79_W200 Offline OP
79_W200  Offline OP
Indiana
I am running indy -1 now. Im getting beat on power tracks wich are common on the clay in the area. The chevys are running schmidt engines that are around 950+ hp i dont think that building a new short block with -1 i can get that budget i would like to be around 25K
1979 W200 470
Re: HEMI heads? [Re: 79_W200] #1290349
08/27/12 07:30 AM
08/27/12 07:30 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Very doubtful with stock head castings. Like many of the SS cars, the intake bolts get too close to the port window, and they need to be changed to the 10 bolt style like you see running in SS now. To date, I have not seen a set of iron heads that way. And the most HP I have seen out of a set didn't hit 900hp, and certainly not for $25k...At that level, there are only a few choices.
