OCD Shaker Bubble Detail #1290025
08/23/12 10:42 AM
08/23/12 10:42 AM
Toronto (YYZ) Ontario
YYZ Offline OP
YYZ  Offline OP
Some pics of an original, assembly-line-correct, scoop assembly and fasteners for the OCD among us.
This is an NOS/virgin part that never even made it to Chrysler back in the day but was kept by a Fram employee. The bubble has never been mounted, emblem holes have not been punched through (still a bit of casting flash).
Re: OCD Shaker Bubble Detail [Re: YYZ] #1290026
08/23/12 10:43 AM
08/23/12 10:43 AM
YYZ Offline OP
YYZ  Offline OP
Black phosphate screw with 'S' marking on head and integral washer holding on the cable at the cold air door.
Re: OCD Shaker Bubble Detail [Re: YYZ] #1290027
08/23/12 10:44 AM
08/23/12 10:44 AM
YYZ Offline OP
YYZ  Offline OP
Black phosphate screw with 'S' marking and 5/8" clear zinc washer holding cable at back of bubble
Re: OCD Shaker Bubble Detail [Re: YYZ] #1290028
08/23/12 10:46 AM
08/23/12 10:46 AM
YYZ Offline OP
YYZ  Offline OP
Black phosphate screw with 'S' marking holding lower leg of RH grille (both are the same)
Re: OCD Shaker Bubble Detail [Re: YYZ] #1290029
08/23/12 10:46 AM
08/23/12 10:46 AM
YYZ Offline OP
YYZ  Offline OP
Black phosphate screw with 'S' marking holding lower legs of LH grille
Re: OCD Shaker Bubble Detail [Re: YYZ] #1290030
08/23/12 10:47 AM
08/23/12 10:47 AM
YYZ Offline OP
YYZ  Offline OP
Clear zinc screws with 'E' marking holding down upper tabs of the grilles, cold air door and ground strap
Re: OCD Shaker Bubble Detail [Re: YYZ] #1290031
08/23/12 10:48 AM
08/23/12 10:48 AM
YYZ Offline OP
YYZ  Offline OP
Note that there is a bit of textured argent overspray, along with some flecks of red primer overspray on the underside of the bubble
Also note that the original grilles are not black throughout like the NOS replacements, but have been quickly sprayed black from the front/top/back leaving plenty of the bare potmetal exposed
Re: OCD Shaker Bubble Detail [Re: YYZ] #1290032
08/23/12 10:48 AM
08/23/12 10:48 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Great detail pics Vlad! I wish I had the loot to grab that one from you
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: OCD Shaker Bubble Detail [Re: YYZ] #1290033
08/23/12 10:50 AM
08/23/12 10:50 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
These ?
Re: OCD Shaker Bubble Detail [Re: gtx6970] #1290034
08/23/12 10:52 AM
08/23/12 10:52 AM
YYZ Offline OP
YYZ  Offline OP
Detail of hot air door attachment - 3 tall, yellow zinc nuts with captive washers. Clear zinc hanger bolts are threaded into the bubble.
Same fasteners used at the far edges of the cold air door.
Actuator rod is clear zinc with black phosphate linkage clips.
Note that the short ground strap has never been crushed down - bubble may be old but it's unused
Re: OCD Shaker Bubble Detail [Re: YYZ] #1290035
08/23/12 10:53 AM
08/23/12 10:53 AM
YYZ Offline OP
YYZ  Offline OP
Markings on original short cable - I will try to get some better pics later as the camera is not agreeing with me...
Re: OCD Shaker Bubble Detail [Re: gtx6970] #1290036
08/23/12 10:55 AM
08/23/12 10:55 AM
YYZ Offline OP
YYZ  Offline OP
These ?
Those are really close. On my bubble, the 'S' marking is within a circle. Also with the integral washer, it looks like yours may have a bit of a flower shape (not perfectly circular) or is it just the photo?
Re: OCD Shaker Bubble Detail [Re: YYZ] #1290037
08/23/12 01:06 PM
08/23/12 01:06 PM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
Holy crap, how did you find that?!
Re: OCD Shaker Bubble Detail [Re: wally426ci] #1290038
08/23/12 01:51 PM
08/23/12 01:51 PM
uk
TiMopar Offline
TiMopar  Offline
uk
Thanks for posting!
Re: OCD Shaker Bubble Detail [Re: TiMopar] #1290039
08/23/12 03:23 PM
08/23/12 03:23 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Nice score...Excellent example for the details...Thanks for posting..
Re: OCD Shaker Bubble Detail [Re: screamindriver] #1290040
08/23/12 07:34 PM
08/23/12 07:34 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Any pics from the topside?????
Admiration For Multiple Carburetor Vehicles...
Re: OCD Shaker Bubble Detail [Re: Stewpar] #1290041
08/23/12 07:41 PM
08/23/12 07:41 PM
western australia
1cuda Offline
1cuda  Offline
western australia
great to see-more pics if you can-some of us will never see things like this in real life.
thanx again
frank.
Re: OCD Shaker Bubble Detail [Re: screamindriver] #1290042
08/24/12 04:41 AM
08/24/12 04:41 AM
Sweden
71redcuda Offline
71redcuda  Offline
Sweden
Great reference pictures. Thanks for sharing!
Re: OCD Shaker Bubble Detail [Re: 71redcuda] #1290043
08/24/12 08:27 AM
08/24/12 08:27 AM
YYZ Offline OP
YYZ  Offline OP
Thanks everyone - I'll put some more up as time permits.
Growing up not far from where these were made has its advantages sometimes.....
Re: OCD Shaker Bubble Detail [Re: YYZ] #1290044
08/24/12 09:56 AM
08/24/12 09:56 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
this post makes me compare mine to it, since mine is also original...
