57 belvedere swap to la318 #1289968
08/23/12 08:37 AM
08/23/12 08:37 AM
NY NY
3
340duster340 Offline OP
NY NY
What is required to put a late80s 318 and 904 combo in a 57 plymouth belvedere?
1966 Dart GT ...down to only 1 mopar for the first time in 15 years!
Re: 57 belvedere swap to la318 [Re: 340duster340] #1289969
08/23/12 10:17 AM
08/23/12 10:17 AM
Nort Cackalacky
rrbrucea Offline
Member known as the "Artist"
rrbrucea  Offline
Nort Cackalacky
This should take care of it...
Sorry, I couldn't resist!
Re: 57 belvedere swap to la318 [Re: rrbrucea] #1289970
08/23/12 11:05 AM
08/23/12 11:05 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
use the old motor(57) mounts on the LA and it should fit right in (unless the old motor was a 6)--if the tranny mount isnt right and you need a generic i would use a 70 caprice--hog out the upper holes to match tranny--drill/or weld a plate with hole to match the lower bolt---there you go....bob
