Best place to order 440-1 heads from #1289235
08/21/12 05:59 PM
08/21/12 05:59 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Hi!
I want to order a set of Indy 440-1 heads.
They are going in a pump gas 512 400 based short block.
Do you think these heads are the best choice???
I would be interested in the complete setup that Indy advertises for around $3900 bucks.
However Id like to have em CNC ported....and blueprinted and gone over by a good shop that knows these heads.
I ahve also heard that is better to stay away from the Indy Rockers and go with the T&Ds or Jesels instead????
Thanks and im all ears....
Re: Best place to order 440-1 heads from [Re: domingo] #1289236
08/21/12 07:21 PM
08/21/12 07:21 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
contact Scott Brown....Buyracingparts.com
He can do the heads very nice and also sells T&D rockers
....BAD A$$ STREET CAR.....
Re: Best place to order 440-1 heads from [Re: n20mstr] #1289237
08/21/12 08:54 PM
08/21/12 08:54 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Is that Scott Brown the guy that makes the custom ground cams?
Re: Best place to order 440-1 heads from [Re: domingo] #1289238
08/21/12 09:00 PM
08/21/12 09:00 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
Or Dwayne Porter....he is a dealer also.
would spec, a cam for what your doing and make sure your heads are flowing, if you want 800hp. tell him..
Re: Best place to order 440-1 heads from [Re: 70blackfish] #1289239
08/21/12 09:01 PM
08/21/12 09:01 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Yes, I was thinking about Dwayne...
Anybody have his contact info???
Re: Best place to order 440-1 heads from [Re: domingo] #1289240
08/21/12 09:04 PM
08/21/12 09:04 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
definatly use a builder through the site here,they cant get bs'd if there is any issue with the head,,,,like indy tries to do
Re: Best place to order 440-1 heads from [Re: domingo] #1289241
08/21/12 09:38 PM
08/21/12 09:38 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
1 802 951 1955
1.39 9.85 - 137 mph
Re: Best place to order 440-1 heads from [Re: Ari440] #1289242
08/21/12 09:49 PM
08/21/12 09:49 PM
Saskatchewan, Canada
cudabin Offline
cudabin  Offline
Jeff at Modern Cylinder Head has a great CNC porting progra for the -1 heads and he is good to work with.
His 345cc CNC port job made 955hp on my 557ci Kieth Black motor.
He will also correct Indy's mistakes...
Good luck,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: Best place to order 440-1 heads from [Re: cudabin] #1289243
08/21/12 10:11 PM
08/21/12 10:11 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Porter
Re: Best place to order 440-1 heads from [Re: 69CHARGERMD] #1289244
08/22/12 01:13 AM
08/22/12 01:13 AM
NEW JERSEY
BIGSPEED Offline
BIGSPEED  Offline
NEW JERSEY
Also Steve Gill at Predator Performance is a Indy dealer.Bill C.
Ceralli Racing Engines & Checkered Flag Machine Racing engines , CNC porting & induction development http://www.checkeredflagmachine.net/
Re: Best place to order 440-1 heads from [Re: cudabin] #1289245
08/22/12 01:18 AM
08/22/12 01:18 AM
Good luck,
Arnie
I called Dwayne originally about CNC porting my Eddy RPM and he said to call Jeff at Modern CCylinder Heads Jeff phone # 586-468-7914. I've had Jeff CNC port several sets of heads for me now, one set of Eddy RPM, one set of B1-BS and two sets of 440-1, all of them made great power
Re: Best place to order 440-1 heads from [Re: Cab_Burge] #1289246
08/22/12 10:39 AM
08/22/12 10:39 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
That's because Dwayne doesn't offer a CNC program for anything but Indy heads. Makes sense to me...
Another vote here for Dwayne Porter as your Go To person for prepped Indy heads.
Re: Best place to order 440-1 heads from [Re: BradH] #1289247
08/22/12 11:16 AM
08/22/12 11:16 AM
oh
julian2007 Offline
julian2007  Offline
oh
Best Machine Race Engines, CHUCK MILLEN OR PETE COSTA
very good mopar guys, built my 588 and it freeking flys
They are a Indy dealer
There number is 248-987-6038
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
Re: Best place to order 440-1 heads from [Re: julian2007] #1289248
08/22/12 12:01 PM
08/22/12 12:01 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
Porter has done several sets of indy heads for me and i have been more than pleased.he even took the time to explaine things so that even a knukle head like me could understand.
Re: Best place to order 440-1 heads from [Re: bonefish] #1289249
08/22/12 12:13 PM
08/22/12 12:13 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Another vote for Dwayne Porter
If I didn't get the 'offer I couldn't refuse' on My Chapman Maxies I would have done a set of 'Porter-1's' on my 517.
If you're doing a pump gasser a higher velocity port (same CFM but smaller cross section for better part throttle torque) might work better than the -1, it really depends on your combo and where you want the powerband to go. Of course there's no doubt a well ported -1's will make MAD power and torque but on pump gas and more streetable cam timing you might produce a broader average torque curve with a 'faster' port that has more velocity down low and through the middle.
WIZE
In Car:
Re: Best place to order 440-1 heads from [Re: Streetwize] #1289250
08/22/12 01:44 PM
08/22/12 01:44 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Add another to Dwayne Porter as he did my heads. He does exellent work and is very pleasant to work with. Top notch. Ron
Re: Best place to order 440-1 heads from [Re: 383man] #1289251
08/22/12 03:46 PM
08/22/12 03:46 PM
Southern IL.
jafr Offline
jafr  Offline
Southern IL.
Might think about Nick Wilson at Compuflow. He hand ports the heads, very nice work. Like Dwayne a nice guy to talk to.
Re: Best place to order 440-1 heads from [Re: jafr] #1289252
08/22/12 09:51 PM
08/22/12 09:51 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Give Nick a call www.compu-flow.com
Gus
64 Plymouth Savoy
Dana 60
Re: Best place to order 440-1 heads from [Re: domingo] #1289253
08/22/12 10:56 PM
08/22/12 10:56 PM
SoCal
Brian Hafliger Offline
SoCal
Hi!
Even though I'm not the most popular guy on here...I am an Indy dealer! Just sayin'
Brian Hafliger
Re: Best place to order 440-1 heads from [Re: Brian Hafliger] #1289254
08/23/12 01:35 AM
08/23/12 01:35 AM
cudabin Offline
cudabin  Offline
Hey everyone, Brian (OU812)is good people...
I have bought a cam and a couple sets of lifters from Brian and he took the time to really think through the specs. The result was a 9.50 with my old 470 stock block motor in the Cuda.
Cheers,
Arnie
