Re: Transmission reverse problem
[Re: Max Weg]
#1289028
08/21/12 02:13 PM
08/21/12 02:13 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Sounds like it's in two gears at once. Does the car creep forward in Neutral? If so, the rear clutch isn't fully releasing.
If it doesn't creep in Neutral, the VB/case mating surface around the accumulator might be warped allowing cross flow between the rear servo and the kickdown servo.
[Re: John_Kunkel]
#1289029
08/21/12 04:08 PM
08/21/12 04:08 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
I had a similar problem after I rebuilt a trans, put in reverse rolls ok..step on gas in reverse it would lock up or bind ..would not move..
I had used one of the plastic style sealing rings on the main input shaft right next to the rear clutch pac..and it had gotten torn during assembly...replaced the sealing ring and trans still working today..
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
