Tunnel ram dimension and availability question
#1288710
08/20/12 07:17 PM
08/20/12 07:17 PM
Posts: 2,490 Sydney,Australia
tex013
Sydney,Australia
For a RB what are the difference in heights between a Weiand and Mopar M1 tunnel rams. i did see the magazine tests.Is it more down to personal choice ? i thought i read a weiand is around 10" with the M1 maybe 1 -11/2" lower. are you able to machine some height out of where the 2 pieces bolt together ? am i correct in assuming the M1 was discontinued 4 or 5 years ago ? does anyone know of one ,M1, for sale ?or are they rare and unusual thanks in advance, Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: Tunnel ram dimension and availability question
[Re: mac56]
#1288712
08/20/12 09:37 PM
08/20/12 09:37 PM
tex013
Sydney,Australia
mac56, do you have the height measurement of the M1 ? with or without carb thanks,
Tex
[Re: tex013]
#1288713
08/21/12 02:50 AM
08/21/12 02:50 AM
tex013
Sydney,Australia
no more thoughts Tex
[Re: tex013]
#1288714
08/21/12 06:49 AM
08/21/12 06:49 AM
Posts: 976 ontario canada
mac56
ontario canada
Tex
Yes I can get that for you. I think I have a low deck M-1 and a low deck wiend. I will look today
[Re: mac56]
#1288716
08/21/12 06:50 PM
08/21/12 06:50 PM
tex013
Sydney,Australia
thanks mac helps in my thoughts/plans
Tex
[Re: Ari440]
#1288718
08/21/12 09:11 PM
08/21/12 09:11 PM
tex013
Sydney,Australia
Ari, saw that but is too tall,only have 14" from valley rail to six pack scoop .Measured a weiand with holley(with choke tower)14 1/4" tall that is why i was looking at info on the M1 thanks
Tex
[Re: tex013]
#1288719
08/21/12 09:33 PM
08/21/12 09:33 PM
Posts: 5,620 long island NY
Ari440
long island NY
I had the M1 tunnelram at one time ,it didnt fit under a 4 inch tall sixpack hood
got a 5 1/2 tall sixpack scoop on the hood now
1.39 9.85 - 137 mph
[Re: Ari440]
#1288720
08/21/12 09:57 PM
08/21/12 09:57 PM
tex013
Sydney,Australia
Ari, have 4" scoop on my satellite to get 14" to RB block valley pan rail.if i run my eddys , no choke tower , i should gain about 1 1/2" to the bonnet - but then air cleaners become an issue.it is a daily driver. if the M1 is 1 1/2" lower might be enough.it's just preplanning at the moment thanks,
Tex
[Re: tex013]
#1288721
08/21/12 11:03 PM
08/21/12 11:03 PM
Posts: 6,621 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
This would be the one you want if clearance is an issue.
It's in the parts section near the top of pg 1.
It was for S/S and as such had to fit under a six-pak hood. The only downside is you will have to make your own 2x4 top as they only came in 3x2 and single 4. Supposed to be THE tunnel ram for an RB.
Kevin
