'98 Neon water pump.
#1288379
08/20/12 02:16 PM
08/20/12 02:16 PM
Posts: 2,525 God's Country Maryland
GODSCOUNTRY340
I want the engineer that designed the water pump on a Neon 2.0 DOHC engine to come to my house so I can knock his face down his throat. If you've ever had to replace one of these you know what I'm talking about. Rant over.
Re: '98 Neon water pump.
[Re: GODSCOUNTRY340]
#1288380
08/20/12 02:30 PM
08/20/12 02:30 PM
Posts: 1,880 Boonton USA
74DartSport
Boonton USA
I wonder if the same in-duh-vidual designed the one on the 2.7l.
Upholding the 74DartSport� brand everywhere.
#1288382
08/20/12 09:15 PM
08/20/12 09:15 PM
Posts: 12,190 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Nothing unique about the Neon set-up. You must not have changed water pumps on any of the transverse mounted engines from the last 20 years or so. Most all of them suck that bad.
The trick to the Neon is to pull the bolts out of the pass engine mounts and jack the engine up as far as it will go for some work and then, let it down as far as it will go for the rest.
Master, again and still
[Re: Dartsport540]
#1288383
08/20/12 09:20 PM
08/20/12 09:20 PM
Posts: 3,424 Portland Oregon
69Dartman
Portland Oregon
I did the one on my 95, what a pain in the rear. I also replaced the timng belt while it was apart. You should always replace the pump anyways when you do the belt seeing how it's driven by the belt and is a interference engine. Took me three days because I've never done one before so triple checked everything and had to buy and barrow tools I didn't have for the job. Still works 15k later so must have gotten it right
Life's a little bit better when you hit a Camaro.
[Re: 71birdJ68]
#1288385
08/20/12 10:50 PM
08/20/12 10:50 PM
69Dartman
Portland Oregon
Well as far as for me I'm sure I could do it a lot faster now that I have more of the tools and some idea of what it takes. At least mine was a SOHC which is probably a few less steps and most of the original parts were fine so saved me some money. My car had the belt done professionally three times before I got it and not once did they suggest or replace the factory pump.
[Re: 69Dartman]
#1288386
08/21/12 02:00 PM
08/21/12 02:00 PM
Posts: 3,663 st louis mo
Q5Bee B5ScatPack
st louis mo
Bump,i think mine has taken a dump this morning.
1969 SUPERBEE 383 Q5 RED STRIPE WHITE INT. 2015 CHALLENGER SCAT PACK B5 BLUE 1996 INDY RAM PACE TRUCK
