cowl drain lines #1288185
08/20/12 02:30 AM
08/20/12 02:30 AM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
where are the cowl drain lines or holes located on a 70 bbody?
Re: cowl drain lines [Re: roy2345] #1288186
08/20/12 03:06 AM
08/20/12 03:06 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
On the very outside edges.. You can see them from under the fender flange where the fender bolts to the cowl. You can run a length of welding rod up in the hole to help clear them..
I am truckless..
