inside water leak #1288066
08/19/12 10:51 PM
08/19/12 10:51 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
I have a 70 satellite and it leaks water in the dash when it rains and when i wash the car. I replaced the wiper gaskets and all and it still leaks inside. I do know that it comes out the drivers inside vent whether its closed or open. And it comes out on passenger side. Anyone have any idea what is causing this problem?
Re: inside water leak [Re: roy2345] #1288067
08/19/12 11:13 PM
08/19/12 11:13 PM
windshield gasket. cowl area (upper firewall)
Re: inside water leak [Re: RapidRobert] #1288068
08/19/12 11:47 PM
08/19/12 11:47 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
Been replaced by the glass guy. But itnleaks when the water gets in the cowl vents. Is there a rust prone area in the firewall?
Re: inside water leak [Re: roy2345] #1288069
08/20/12 09:56 AM
08/20/12 09:56 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes , the bottom of the cowl can rot if it gets filled with leaves and/or pine needles and dirt , water can't drain and the poor protection originally applied to that surface is compromised.
Re: inside water leak [Re: roy2345] #1288070
08/20/12 10:58 AM
08/20/12 10:58 AM
central Florida
VL21 Offline
VL21  Offline
central Florida
Not sure of B bodies, but on my A there is a lip, about 1 or 1-1/2" tall above the floor of the cowl, for a water dam sort of thing, surrounding the opening for the vent, and mine had rusted mostly away, contributing greatly to the non existant right floor pan...
Not sure how the B is attached, on my A the heater/right vent are attached by(among other things) "J" bolts, IIRC.
If the water is dripping from the inside of your vent, I would look here.
It takes gasoline to interest me.
Re: inside water leak [Re: VL21] #1288071
08/20/12 11:28 AM
08/20/12 11:28 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
B body has the same lip .
Re: inside water leak [Re: JohnRR] #1288072
08/20/12 09:55 PM
08/20/12 09:55 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
Thanks willook there and report back this week....thanks guys!
