Re: Composite parabolic mono leaf springs?
[Re: Locomotion]
#1287296
08/18/12 12:50 PM
08/18/12 12:50 PM
Posts: 5,160 Texas
dannysbee
Texas
Myron if you have a wore out pair of SS springs take them to a local spring shop and have them use them as a blue print. We did this years ago and it was not that expensive and they worked and lasted great. I know that is not what you asked but it is another option.
Getting old just means you were smarter than some and luckier than others.
[Re: Locomotion]
#1287298
08/18/12 01:11 PM
08/18/12 01:11 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Are you refering to the Landrum springs?
[Re: Thumperdart]
#1287299
08/18/12 01:54 PM
08/18/12 01:54 PM
Posts: 5,894 Florida
Locomotion
The springs my friend sells are "Flexiform" and says that they can be made for any application. But it still seems like they would need to absorb a lot of stress. I haven't talked to him about these yet but he has been encouraging me to get a Cal-Trac set-up for a while. If I ever do get Cal-Tracs, it would have to be in the off season. Don't like changing big things in the middle of a season. Only concern there is, if at the last minute,have to remove weight for a heads-up run or add weight at a really bad track. I've heard of a few such situations where traction was worse because re-adjustments weren't made. With just leaf springs, I can add/remove whatever weight I want anytime. I'll have to ask the local driveline/4x4 guys if the can duplicate SS springs, but with better material. However, it would be nice to have a lighter suspension with "optional" weight available to be added/removed. Cal-tracs do seem like the best idea.
[Re: Thumperdart]
#1287301
08/18/12 03:00 PM
08/18/12 03:00 PM
Posts: 5,160 Texas
dannysbee
Texas
The place that I used was in Ft. Worth Texas Champion Spring. They actually had blue prints for many springs but we just had some we had duplicated.
[Re: jcc]
#1287303
08/18/12 03:49 PM
08/18/12 03:49 PM
Posts: 11,713 Portage,michigan
B3422W5
Portage,michigan
My thoughts Myron.... You have been wildly sucessful with s/s springs, as the old saying goes, if it doesnt stink, dont stir it. Being a long time member on the board here, i have to say there have been( in my opinion) probably more posts from guys trying to get cal tracks to work, or this adjustment or that than anything else i have ever read on here. I had great consistancy on a 9 sec car with s/s springs even with a very small tire. At where your car runs/ET, and the luck you have had with it, i would try and get a new set of springs made just like what you have.And stick with that winning formula.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: Locomotion]
#1287306
08/18/12 06:35 PM
08/18/12 06:35 PM
Posts: 133 Winter Park, Florida
classracer
Myron; What I have done is to have a few different settings for different vehicle weights and different classes. These settings on the caltracs were recorded as used , but with me out of the car. This way I can change them quickly with two wrenches and no extra help....Jim
70 Challenger A/SA 2441
[Re: Locomotion]
#1287309
08/18/12 10:10 PM
08/18/12 10:10 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Myron is Flexiform a split spring(front/rear)... if so have them make you up a real stiff front and the rear to what your car weighs... that should give you the best of both worlds... stiff front like the SS (which could have been stiffer) and the ability to move weight if needed... if they can build you a really stiff front then all you need is the shock to control it
[Re: Locomotion]
#1287311
08/19/12 12:10 AM
08/19/12 12:10 AM
Posts: 22,696 Bitopia
jcc
Bitopia
Did you see this thread? https://board.moparts.org/ubbthreads/show...e=2#Post7018581And technically "parabolic" springs are not mopar style, mopar are aysemetrical as mr p mentioned earlier
[Re: jcc]
#1287312
08/19/12 01:20 AM
08/19/12 01:20 AM
Posts: 553 Kentucky
clovis
Kentucky
I had a similar conversation with Alex Moneymaker at PRI (Cal-Trac booth) I was looking to make the move to the Caltrac, when he mentioned the composite spring. I actually looked pretty hard to see if I could get the Astro van springs to work after talking with him. I was never able to find much info in regards to the Mopar side of the house. I wound up going caltrac and the car sixty foots a little better but is much more consistent which seems to be a common comment.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
