452 Heads #1287192
08/18/12 02:34 AM
08/18/12 02:34 AM
Annapolis Maryland/WV
dmnrr04 Offline OP
dmnrr04  Offline OP
How well do 452 Heads flow ?
Do the MP BB Porting Templates work ?
How well do the MP BB Porting Templates work ?
Where can I find the instructions on how to us MP BB Porting Templates ?
Re: 452 Heads [Re: dmnrr04] #1287193
08/18/12 02:46 AM
08/18/12 02:46 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
They flow equally to a 346 0r a set of 906s. If you were to run a dyno test with all 3 you would hardly see any difference.
Yes the templates will work on all 5 BB heads except for the Max Wedge heads. . I did a set with oversize valves,very mild pocket porting and a gasket match. That made a world of difference.
Just start grinding to match the templates. They are marked for the amount of material to revove IIRC.
I am truckless..
Re: 452 Heads [Re: 340SHORTY] #1287194
08/18/12 07:46 AM
08/18/12 07:46 AM
dmnrr04 Offline OP
dmnrr04  Offline OP
Do you have the instructions on how to use them and where ?
Thanks,
Rick
Re: 452 Heads [Re: dmnrr04] #1287195
08/18/12 10:02 AM
08/18/12 10:02 AM
see if you can find Dulcichs' Mopar Muscle porting articles. Google it. Good info. You trim them on the outside edge of the black lines if using 2.08/1.74 valves. if using 2.14/1.81 you'd cut them out then use them in the leftover plastic to cut new ones that are wider by .060" (.030" on each side) for instance on the intakes (2.14-2.08=.060"
