Length of AAR Cuda - T/A Challenger radio antenna cable #1287072
08/17/12 02:09 PM
08/17/12 02:09 PM
N.E. OHIO, USA
A12 Online content OP
A12  Online Content OP
N.E. OHIO, USA
Anyone know the length of an original AAR Cuda or T/A Challenger radio antenna cable? Was it just an extension with a male and female end or was it one piece from the antenna to the radio?
I have a 142" radio antenna extension cable on my '69 A12 road runner that had the antenna moved to the rear quarter/fender back around '69 or '70 and I was thinking if it was aound '70 that they may have used the AAR or T/A antenna lead to do that?
Thanks.
Here's the 142" male/female end antenna lead that's been with the car since circa 1970, is this what was maybe used for the AAR or T/A?
Re: Length of AAR Cuda - T/A Challenger radio antenna cable [Re: A12] #1287073
08/17/12 02:10 PM
08/17/12 02:10 PM
N.E. OHIO, USA
N.E. OHIO, USA
The antenna location on the right rear:
Oh and the reason it was moved to the rear as some of you know was because of the lack of radio interference shielding from the fiberglass lift off hood and the same goes for the rear location for the T/A and AAR. (had to have learned that from the previous year's A12 owners complaints)
Re: Length of AAR Cuda - T/A Challenger radio antenna cable [Re: A12] #1287074
08/17/12 11:06 PM
08/17/12 11:06 PM
Iowa
TX9AAR Offline
TX9AAR  Offline
Iowa
I will go measure mine tomorrow I have it out right now
Re: Length of AAR Cuda - T/A Challenger radio antenna cable [Re: TX9AAR] #1287075
08/17/12 11:25 PM
08/17/12 11:25 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The AARs & T/As used two cables connected together, so what you have would not be from the same application.
