Re: tuning vaccum advance on ported vaccum source.
[Re: pjc360]
#1286152
08/16/12 07:52 AM
08/16/12 07:52 AM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
Connecting vac advance to the manifold leads to very unstable idle, esp. w/ automatic.
50-plus degrees, as noted above, isn't a problem, it leads to increased fuel economy, and, more importantly, lots less fuel wash / ring and cyl. wall wear. All the stock OEM hi-po engines were in the 50-55 degree range. Sound crazy? remember that the second you tip into the throttle, the spark gets pulled way back.
Rick
[Re: pjc360]
#1286153
08/16/12 10:36 AM
08/16/12 10:36 AM
RapidRobert
I'd set the initial it wants with the vacuum gauge method then with that figure in hand shorten the slots to get 35 total (initial on ported/total with vac adv plugged). Then I'd mix/match springs staying just under the pinging point at WOT up thru the gears on your hottest/dryest (most likely to ping) day THEN plug in your vac adv & adjust its' curve (clockwise with a 3/32" allen wrench=faster) to come in as fast as possible staying just under the pinging point on your hottest/dryest day at PART throttle (high vacuum) such as a highway steady cruise at an RPM at or above where your mech adv is aqlready maxed out. When all good there take it out at varying speeds/loads & if any ping then reduce the vac adv curve (clockwise) EDIT meant to say counter clockwise
[Re: Rick_Ehrenberg]
#1286158
08/16/12 10:52 PM
08/16/12 10:52 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
If there is enough manifold vacuum at idle in D so that the can stays fully advanced (against its stop), won't that eliminate the instability? ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
There seems to be a can that's fully advanced at 8" (Echlin VC-1810) and it has a variety of different part numbers: (sorry for the Camaro link) ![](/ubbthreads/images/graemlins/grin.gif) http://www.camaros.net/forums/showthread.php?t=166489
[Re: DrCharles]
#1286162
08/17/12 07:41 AM
08/17/12 07:41 AM
Posts: 5,444 Indiana
YO7_A66
Indiana
""If there is enough manifold vacuum at idle in D so that the can stays fully advanced (against its stop), won't that eliminate the instability?"" Yes!!! Once you know your in D idle vacuum reading, then choose the correct can. I would suggest that you run a can that is 1+" below your existing vacuum reading in D. I am currently running a distributor that spec's out the need for 12"hg to keep the can fully advanced. I have tested it with 11.5"hg and the idle starts to float. If I stay above the 11-3/4"hg reading then the idle is steady with the manifold vacuum. My setup makes 11-3/4-12"hg at idle in D, and that is too close to suggest to someone else. This is why I suggest that anyone tries a can 1+ less than their actual in D vacuum reading.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: pjc360]
#1286166
08/19/12 11:34 PM
08/19/12 11:34 PM
RapidRobert
Sounds like you're pretty good. If you wanted to experiment with manifold you could reduce the initial then lengthen the slots to maintain 32 total (or even a bit more) EDIT I would drill a 3/8 hole in the top of a junk dist cap 2/3 of the way between center & #1 & check rotor phasing as vac adv alters phasing & you would not want to reduce timing IF rotor phasing (which can be corrected) is the culprit
[Re: pjc360]
#1286168
08/20/12 01:40 AM
08/20/12 01:40 AM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
my distributer was curved and phased on a distributer machine. don from fbo systems built my distributer and according to him it is phased and curved correctly. I told him what my engine is wich is the 300hp crate 360 magnum told him what it is in and what my gear ratio is and what size tire i run and he curved it based on all the information and phased it.
Don knows his stuff. He will have it waaaaay closer than a factory dist, or a reman out of the box would ever be.
That said, I've seen him recomend using manifold vac, and that just doesn't work on most of them. It ads too much at idle, especially if the curve has been shortened to run more intial.
Run his curve with 34 total and the base where it falls, and that'll be pretty darn good ![](/ubbthreads/images/graemlins/Twocents.gif)
