first road course car build -73 dart sport
#1286030
08/15/12 10:30 PM
08/15/12 10:30 PM
Posts: 168 Washington State, USA
Winchester 73
hi;ive been lurking for a long time trying to get a little less stupid before i start talking about what i want to do. i have a gutted dart sport with the following stuff already installed- car: cordoba brakes longer wheel studs dakota 3.55 open 8 1/4 rebuild stock 727 mustang svo 17" wheels 318 torsion bars manual steering motor: 383 40 over cast rebuilder pistons street hemi cam hammer-to-fit under chassi headers weind intake have several carbs to choose from me: i am poor and have a blackbelt in oldschool mopar-junkyards ,swapmeet,craigslist,ect.i used to be a chevy guy and one of the things that made me switch was mopar guys tended to use brains,hard work and creativity before credit cards.i miss the days when there wasnt thirty different aftermarket bigblock heads.money for me puts a stink on a car,i dont like driving money even if its fast.car must be streetable-ish.car will be light,i mean really light. things my car will NOT have: shocks that cost more than my car(billstiens ect) manhole cover size brakes tranny that costs more than my car (viper ,ferrari,ect) fuel injection smallblock nice paint so there it is ,please any help would be cool.this car is intended to run at shelton wa and seattle wa raceway.
Re: first road course car build -73 dart sport
[Re: Winchester 73]
#1286031
08/15/12 10:49 PM
08/15/12 10:49 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
If you have a welder, start with the K member and any seam in the body you feel comfortable welding. I have an iron headed B motor A body with a glass hood and it isnt as nose heavy as people think but aluminum heads are on the want list.
Mopar to the bone!!!
[Re: 72Swinger]
#1286032
08/15/12 11:02 PM
08/15/12 11:02 PM
Posts: 1,491 Lethbridge, AB, Canada
dangina
firm feel is in your neighborhood, you should check them out!as for on the cheap, even used mopar parts are getting harder to find in junkyards, its almost cheaper to buy aftermarket now unfortunatly. But you can make your own subframe braces, inner fender braces, lower rad brace, engine brace, roll cage ect if you have a welder handy
[Re: Winchester 73]
#1286034
08/15/12 11:25 PM
08/15/12 11:25 PM
Posts: 22,696 Bitopia
jcc
Bitopia
How much road tace track do you s a driver currently have under your nelt?
My next suggestion is kinda based on the answer, but you will have a lot more fun, spend a lot less mpney, learn a lot more faster imo if you store that 383 under the bench and just get a decent free stock 318 and beat it to death while sort everything else and driver gets his chops. I know you don't want to hear this, but.......
[Re: jcc]
#1286040
08/16/12 12:46 PM
08/16/12 12:46 PM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
So, I guess when building a dedicated track car, I'd have to ask about the specific application. Is this used in a specific racing class that has a rule set we need to be congizant of or is it simply being run in open track days for seat time and fun?
If class specific, rules will dictate pretty heavily what you need to do to be competitive. If open track days, then absolute time is inmaterial and horsepower isn't a factor. Suspension always will be a factor, but road courses tend to be flatter with more transitional response requirements, so unfortuantly to your obejectives, shock performace will be paramount to driving enjoyment and may drive the cost up.
If you really don't want to spring for expensive shocks, I'd recommend looking at how you can adapt GM F,A, or G body dampners to you mopar locations. This will open up the selection of used, low cost dampners as the oval track guys tend to swap out shocks pretty regularly and resell them very cheaply. I used to pick up used Pro and Carrera steel body fixed rate shocks for around $15-20 each at swap meets. But, will rules allow this?
For cheap, it only costs labor mods, welding up seams and fabrication of stiffening components will go a long, long way to making everything else work well together. Emphasis on the front third of the car is where the most gains come from. But again, is this within the rule set if its a competition car?
