Need pic 70 Roadrunner Hood Turnsignal wiring #1285921
08/15/12 07:09 PM
08/15/12 07:09 PM
Texas
70Runnerdude Offline OP
Texas
Hello I tried this post on question and answer but never recieved any pics so ill try it here.
I am looking for a pic of the wiring warness that goes from the firewall to the hood for the hood mounted turn signals most important area I need is of the firewall area.
Any help would be greatly appreciated !
Re: Need pic 70 Roadrunner Hood Turnsignal wiring [Re: 70Runnerdude] #1285922
08/15/12 08:19 PM
08/15/12 08:19 PM
St.Louis,Mo.
70RR383 Offline
70RR383  Offline
St.Louis,Mo.
Here ya go,2 wires that travel through the hood to conections(in my hand)then travel down the fender to the front
Re: Need pic 70 Roadrunner Hood Turnsignal wiring [Re: 70RR383] #1285923
08/15/12 08:20 PM
08/15/12 08:20 PM
St.Louis,Mo.
70RR383 Offline
70RR383  Offline
St.Louis,Mo.
another
Re: Need pic 70 Roadrunner Hood Turnsignal wiring [Re: 70RR383] #1285924
08/15/12 08:37 PM
08/15/12 08:37 PM
Texas
Texas
Awesome thankyou thankyou thankyou !
Do the wires go all the way up front to the actual turn signals in the bumper or how far does it go. Also how is it connected to the wiring harness up on the front area of the fender is it a plug in type thing or is it actualy part of the main wiring harness ?
Sorry for all the questions I just want to make things right on the car is all.
thanks!
Re: Need pic 70 Roadrunner Hood Turnsignal wiring [Re: 70Runnerdude] #1285925
08/15/12 08:47 PM
08/15/12 08:47 PM
St.Louis,Mo.
70RR383 Offline
70RR383  Offline
St.Louis,Mo.
I dont know that,I would have to go crawl under car.I just took those tonight and covered the car back up.I will check this weekend.Dont you have a service manual??
Re: Need pic 70 Roadrunner Hood Turnsignal wiring [Re: 70Runnerdude] #1285926
08/15/12 09:23 PM
08/15/12 09:23 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
thanks!
If I am reading the wiring diagram correctly it shows the harness from the hood turn signal wires plugging in to the firewall junction block.
The wiring diagram came from Mymopar.com and can be found here;
http://www.mymopar.com/index.php?pid=27
Re: Need pic 70 Roadrunner Hood Turnsignal wiring [Re: moparfan53] #1285927
08/15/12 11:26 PM
08/15/12 11:26 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
thanks!
As I posted in the other thread, this is correct, the pigtails come from the bulkhead connector...The bullet style connectors posted above are used on the lamp assembly but not near the bulkhead connector.... The connectors near the bulkhead are Packard 58 style connectors.. Oh, and most 70 plymouth forward light harnesses don't have the pigtails....
Re: Need pic 70 Roadrunner Hood Turnsignal wiring [Re: 1_WILD_RT] #1285928
08/16/12 09:08 PM
08/16/12 09:08 PM
Texas
Texas
Ok I guess this is not for a 70 Roadrunner then. I was told it is but could not figure out how it would connect.
Re: Need pic 70 Roadrunner Hood Turnsignal wiring [Re: 70Runnerdude] #1285929
08/16/12 09:59 PM
08/16/12 09:59 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Actually, I think it is correct. Seeing the the pic and re-reading the info from 1 WILD RT jarred my memory. It is the harness I outlined in green. It plugs into a connector/pigtail in the firewall area that is part of the front light harness. It is a similar hookup on a 69 Charger, I can post a pic of the Charger harness tomorrow if you want.
Re: Need pic 70 Roadrunner Hood Turnsignal wiring [Re: 70Runnerdude] #1285930
08/16/12 11:37 PM
08/16/12 11:37 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Well, thats a Packard 58 style connector for near the bulkhead & bullet connectors for the plugs near the hood... Looks right to me... But I'd forgotten that the Packard connector was a single duplex not two singles.... Hey, it's been 12-13 years since I worked on one...
Re: Need pic 70 Roadrunner Hood Turnsignal wiring [Re: 70Runnerdude] #1285931
08/17/12 01:02 PM
08/17/12 01:02 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Here are 2 pics of 69 Chargers for reference, even the color coding on the wires (tan & green tracers) is the same as shown for the 70 RR. The red car did not have the hood turn signals from the factory, they were added. However the connector was already there, but not obvious to see at first. It was folded back and taped up to/in the harness.
Hope you get lucky and find it on your car also!
Re: Need pic 70 Roadrunner Hood Turnsignal wiring [Re: moparfan53] #1285932
08/19/12 07:11 PM
08/19/12 07:11 PM
Texas
Texas
Finaly got around to taking off all of the stuff on my Roadrunners hood to see if it had the plug for the hood mounted signal lights and it has it. Here is a pic.
